Author Topic: moving battery to rear  (Read 1870 times)
Offline DunnDeal12
  • Limited
« on: 29 July 2012, 16:07 »
Can anybody tell me whats involved in moving the battery to the rear (spare wheel well) of my mk4? is there any how to guides?
Offline leigh_harty
  • Audi AGU
Re: moving battery to rear
« Reply #1 on: 29 July 2012, 16:32 »
!st thing i would so is go to the scrappy and strip some cables out of an e36 beemer
Dont lose your dinosaur!
Offline DunnDeal12
  • Limited
« Reply #2 on: 29 July 2012, 16:35 »
Why? do tell :wink:
Offline leigh_harty
  • Audi AGU
« Reply #3 on: 29 July 2012, 16:37 »
they have their batteries in the boot so you would have (i presume) all the necessary starter cables needed
Offline mcgee9t2
« Reply #4 on: 29 July 2012, 19:03 »
Firstly you un bolt the battery. then you put in the boot. then you pat yourself on the back for a job well done.
no seriously. Have a look on ebay for a bracket. put the bracket in the foot well. take the cable off the starter. run a new longer cable through thefire wall (gromet behind the glov box) down to the boot. then again disconect the negative cable and run to battery aswell. job dobe
Offline stfc_gti
« Reply #5 on: 29 July 2012, 19:06 »
why would you move the battery to the back? is it for weight distribution?
2002 1.8T GTI AUM, Standard (not for much longer)
Offline mcgee9t2
« Reply #6 on: 29 July 2012, 20:00 »
ive seen people do it for weight distribution. but in a mk4 a batterys not gonna make any difference :D
some do it to clean up the engine bay
Offline DunnDeal12
  • Limited
« Reply #7 on: 29 July 2012, 20:03 »
correct
mines abit nose heavy atm as ive took the rear seats out and space saver. plus cleaner looking bay
do you think this would work just buy x2 and run from front to back?
http://www.demon-tweeks.co.uk/motorsport/battery-cable-connectors/auto-marine-power-jointing-boxes
Offline EsSeX dAn
« Reply #8 on: 29 July 2012, 21:08 »
as said use a wiring kit from a beemer. then use a battery tray again from a beemer, or use a universal one or a sealed box with a vent to outside. either way you have to vent it to outside,i cut 2 30mm holesin the floor and simply ran some alloy tube araldited in place to finush it
i think i love you.....
« Reply #9 on: 29 July 2012, 21:31 »
Needs to be a sealed battery with a vent to the outside world but easy enough to sort.
