Author Topic: Vag com help  (Read 1290 times)
Offline lozza07
Vag com help
« on: 29 July 2012, 10:01 »
Hello there
I have  a 1997 GTI AGG engine.
I'm looking at buying a vag com.
Can anyone recommend a particular brand, and where to buy from?
Thanks in advance
Offline Screech16v
  • MK3 20vt AGU
Re: Vag com help
« Reply #1 on: 29 July 2012, 12:48 »
Hi mate do you mean you want to buy a fault code reader or actually vag com itself
http://www.talktomycar.co.uk/products/codereaders/codereaders.htm
Offline itavaltalainen
Re: Vag com help
« Reply #2 on: 29 July 2012, 13:23 »
vag-com or now vcds is made by ross-tech, they offer full kits but it's a bit expensive but guaranteed to work.
if you want to use vag com you can with a KKL 409 interface cable off ebay but then you have the issue of vagcom not being activated - and you only have basic functionality - i.e. can only read fault codes (not even full fault text for those codes).
