Author Topic: Head Blower - Poor / Slow / Powerless  (Read 1863 times)
Offline knobby
« on: 29 June 2005, 01:03 »
Hi guys
since the hot weather has arrived ive noticed how poor my interna blower is at pushing fresh air out the vents even on three i can heardly feel it on my face. u can feel it coming up the vents just not very hard. How does this compare to others.. ive got air con (which doesnt work) so i wasnt sure if this would slow it down as its been disconnected.
Any ideas?
Knobby!!!
Old VW's never die...they just go faster!
Judderi
Re: Head Blower - Poor / Slow / Powerless
« Reply #1 on: 29 June 2005, 12:57 »
On mine it comes out nice and strong especially on number 3. Have you got your direction slider on the right option? If you have in on windscreen only then not much comes out the vents. But if you put it on vents only its like a wind tunnel!
Offline knobby
« Reply #2 on: 29 June 2005, 14:45 »
Its on in ya FACE FULL.. but doesnt really come out that fast.. Ive got air con.. but didnt know if that made a different. do you know?
KNOBBY!
Judderi
« Reply #3 on: 29 June 2005, 14:48 »
Sorry i dont know if air con makes a difference. Could be a weak motor - the bit under the dash in the passenger side.
Offline knobby
« Reply #4 on: 29 June 2005, 14:51 »
recon u could be right.. might connect it directly to a 12v batt and see how she goes... Its defo a bit weak!!!!
MORE MONEY!!!  :cry:
Knobby
Judderi
« Reply #5 on: 29 June 2005, 14:54 »
Mines quite noisy when on full as its spinning real fast.
Offline knobby
« Reply #6 on: 29 June 2005, 15:03 »
umm.. i recon it needs replacing then.. as u can hardly hear mine.. DOH!
Thanks for the advice!
KNOBBY!
Judderi
« Reply #7 on: 29 June 2005, 15:21 »
Try running a fresh live direct from the battery like you said 1st. You might just have a corroded or faulty wire.
