Author Topic: AXEL STANDS ON GOLF GTI  (Read 1130 times)
Offline arran.concept
  • Yellow Colour Concept
« on: 28 July 2012, 12:51 »
Can someone tell me where i can put the axel stands under my car once ive jacked it up?? thanks.
Detailed answer would be appreciated
VW BUSH
Re: AXEL STANDS ON GOLF GTI
« Reply #1 on: 28 July 2012, 13:41 »
At the rear you will see a reinforced box section just in from the rear jacking points and in front of the rear beam pivot mounting.
At the front you will see a box section coming out of the floor and leading up to the fixing point of the inner suspension, get it up just after the first bolt on the plate If your stands are wide enough.
There is another  jacking point in between the suspension and the sill, which i avoid as ive had one go through with a nice rusty crunch :shocked:
