Author Topic: Coolant Gauge and Light woes  (Read 8948 times)
Offline robw09
Re: Coolant Gauge and Light woes
« Reply #10 on: 28 July 2012, 21:50 »
Ok, unplugged the black temp sensor and bridged.  As the gauge was already at max nothing happened, but when I removed the bridge the gauge steadily dropped to min and light went off.  When I put the plug back on the light came back on a gauge shot to the top.
I bridged the coolant bottle sensor when the light was off and gauge was at min.  And it did make the light come on and then off again.  So, I now believe, with your help  :grin:, that the black sensor is knackered.  Is that right?
Local stealer has one in for £24 or GSF for £8....leaning toward stealer.
Many thanks for help.....I need to post a pic of car once I have done everything!
Just need some genuine mats, find a new tape holder for dash and then a nice powerful cassette radio with green backlighting that will fit!
Rob
Offline Jimmyrallye
  • 20vt goodness
« Reply #11 on: 28 July 2012, 21:55 »
Were is the black temp sensor located ? Just tried the bridge test on mine and my light still never came on .. What did you brigge it with ? One good thing out of the last hour wos just changed my fog light bulbs so not all bad
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #12 on: 28 July 2012, 22:07 »
Front of the block...
Rob
Hi Rob,
Glad you seem to have found it...
I would still get a new cap!!
For More Info Click To See;
Offline Jimmyrallye
  • 20vt goodness
« Reply #13 on: 28 July 2012, 22:40 »
Arghhhh there she is  :wink: cheers dude
Offline Gambit
« Reply #14 on: 30 July 2012, 02:05 »
By a dealer part. Worth it in the long run
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #15 on: 30 July 2012, 02:06 »
+1+2+3+4
Offline mk2bal
« Reply #16 on: 30 July 2012, 11:03 »
Not so important, it purely feeds the dash guage, the blue one does the ecu and accuracy is critical, the black one as long as you know where it normally sits (even if untrue) is fine. I've got a few in the shed pinched from scrappies, but up to you depending on what you see as worth it...
Offline Jimmyrallye
  • 20vt goodness
« Reply #17 on: 30 July 2012, 21:38 »
Rightyo been fiddling with the golf again ;) done the black temp sensor trick and my temp gauge shot straight up !! But as soon as i bridged the coolant temp sensor nothing no light or anything does that mean my expansion tank sensor is goosed ?
Offline robw09
« Reply #18 on: 30 July 2012, 21:45 »
I wish you would have told me that before I bought one from the stealer  :wink:
Anyway, replaced the sender and no more light/gauge woes, huzzah!
Right, next job find a good body man in Lincoln to pull a couple of small dents out polish out a scratch.  Then order some nice new 4x6 and 3.5" speakers.....
