« Reply #20 on: 30 July 2012, 13:11 »
fluttering is normally the DV, but you can get very odd noises dependant on the filter setup
I am going to put the venom back on, as I did brake the sai hose clip, and had to tape it to the air box. may be that may have something to do with the fluttering then?
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
