Author Topic: Turbo lag  (Read 4169 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Turbo lag
« Reply #10 on: 29 July 2012, 18:22 »
possibly DV sticking or split pipe to it
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
Re: Turbo lag
« Reply #11 on: 29 July 2012, 21:19 »
Ahh ok, thanks. There are no split pipes, but it does sound a little bit like the pipe has split, because this happened a while ago, and sounded similar.
What do I do to find out if it is sticking? If it is, can it be fixed. I have an Awesome Forge dv
thanks
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Turbo lag
« Reply #12 on: 29 July 2012, 21:21 »
In the words of Groundskeeper Willy "Grease me up woman!!"
Re: Turbo lag
« Reply #13 on: 29 July 2012, 21:32 »
 :grin: :laugh:
Ok then, any particular grease a need to use, seriously I wouldn't have a clue what to use  :laugh:
Offline pickles
  • Next!!!
Re: Turbo lag
« Reply #14 on: 30 July 2012, 11:32 »
weirdos on here i tell you ;)
mk4 golf 1.8T, AGU, CAI, Forge007p DV,TIP,Decat, Bilsteins with Koni springs dropped 40mm
Mapped
Nearly S3 time  :)
Re: Turbo lag
« Reply #15 on: 30 July 2012, 12:22 »
Re: Turbo lag
« Reply #16 on: 30 July 2012, 12:23 »
If the DV is sticking, would that cause power/boost issues?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Turbo lag
« Reply #17 on: 30 July 2012, 12:33 »
if it was stuck open it would just bleed your boost off
Re: Turbo lag
« Reply #18 on: 30 July 2012, 12:49 »
If it was stuck open, is that what that fluttering sound would be, because there is no split pipe at all. because my car feels like it wants to go, but then doesn't
Thanks
Offline Dalo Harkin
Re: Turbo lag
« Reply #19 on: 30 July 2012, 12:59 »
fluttering is normally the DV, but you can get very odd noises dependant on the filter setup
