Author Topic: How to check engine mounts?  (Read 2039 times)
Offline Wisey
« on: 26 July 2012, 16:27 »
Made a thread about my car not feeling right. And I have changed the wishbone bush and the dog bone mount. And It didn't make any/very little difference  :undecided:
So thinking it might be the engine mounts that are gone? There is a wee bit of play in the passengers side wheel but only if you put your hands at 3-9 o'clock but no play at 12/6 o'clock. And there is no visible play in the bushes or ball joints  :undecided:
I know that the steering rack is leaking on that side but there is no play in that.
So only thing I think it could be is the engine mounts?  :sad:
Offline barrym381
Re: How to check engine mounts?
« Reply #1 on: 26 July 2012, 17:13 »
sounds like a track rod end worn  :smiley:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 26 July 2012, 17:22 »
I just started my car from cold while looking at the engine. It looked like it wanted to escape lol
Offline barrym381
« Reply #3 on: 26 July 2012, 17:29 »
:laugh: :laugh:
Offline Wisey
« Reply #4 on: 26 July 2012, 17:31 »
Engine really doesn't move that much  :sad: but you can feel vibrations through the car when its sitting idling.
And I also replaced the outer track rod ends maybe 10,000 miles ago, dont know if you can change the inner ones on the golf?  :undecided:
Also if your on the motorway doing 50+ and you turn the wheel sharply left then right you can feel the front wheels 'wobble' as well.  :rolleyes:
Really out of ideas now, checked all the bolts are tight etc as well and nothing. And not looking to spend alot on it because after I finally find a new car its getting broken for parts  :cry:
Offline barrym381
« Reply #5 on: 26 July 2012, 17:34 »
sounds bush related so should not be much to sort  :smiley:
Offline Wisey
« Reply #6 on: 27 July 2012, 12:54 »
Hope so but dont know what I should try replacing next  :undecided:
Offline barrym381
« Reply #7 on: 27 July 2012, 12:55 »
who has been doing the work so far  :smiley:
Offline Wisey
« Reply #8 on: 27 July 2012, 14:59 »
Stuff like bushes etc I have just been doing my self.
Quite handy with a spanner. But just cant see any play in any of the bushes or ball joints at all...
Offline Xtrhardcore
  • Mk3 Gti 2.0 8v MoreDoor
« Reply #9 on: 27 July 2012, 15:07 »
For the sake of the track rod ends they're like £15, so if you can, you might aswel replace them anyway, may make a difference?
Mk4 Gti - Gone but not forgotten!
