Author Topic: Car getting hot after rebuilding front end...  (Read 5427 times)
Offline Deano2711
  • 1992 VR6
Re: Car getting hot after rebuilding front end...
« Reply #20 on: 26 July 2012, 22:09 »
Temp sender is locater where the top hose meets the block....the top hose goes to a large block and the temp sender sits at the top. When the engine is cool remove the plug and then push down on the temp sender and pull out the retaining clip and its out. My temp sender was yellow but think there are a couple of colours. Worth changing to ensure the temp guage is giving an accurate reading.
Offline 67buggers
« Reply #21 on: 27 July 2012, 06:26 »
Have you checked your fan is wirking ok? Could be your fan switch sensor.... Not expensive and easy to swap. Mine wouldnt kick in when it got to temp and that wad the cause alOng with the thermostat.
I fix iPhone's and iPod's, I can fix most faults call me on 07811344816 for a quote
Offline MK3 Menace
  • 98 GTI, big changes are coming...
« Reply #22 on: 27 July 2012, 12:42 »
I am going to do this tomorrow now as work has got in the way.
I am going to do the following, if you guys think I need to do things differently let me know.
1. Drain and refill using more coolant.
2. Bleed system with cap off and fans on full.
If that does not cure it I will.
1. Replace temp sender.
2. Check fan wiring.
3. Replace thermostat.
4. Check water pump out.
Dan
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
« Reply #23 on: 27 July 2012, 18:09 »
If your draining the coolant you'd be better doing the thermostat at the same time as will save you draining it twice if it turns out to be the problem. I'd put money on it being the thermostat.
