Author Topic: Car getting hot after rebuilding front end...  (Read 5444 times)
Gavv8
Re: Car getting hot after rebuilding front end...
« Reply #10 on: 26 July 2012, 21:26 »
I am starting to think I may have been a bit stingy with the coolant. I am going to drain it all off later and start again.
It has two fans down there connected off each other via a belt but didn't know if one was for Air Con or something.
I'll try again with coolant and then will tackle the thermostat if its not kicking the fans in still.
Left the car at 90 for a good 10 minutes I reckon and no fan...
That doesn't sound right..
Under the slam panel are two fans side by side, they have a small belt that drives one from the one with the motor. I can show you a pic if you like as I got the old slam panel I took off to hand...
Yes please, i thought twin fan rads had two seperate motors.
Offline MK3 Menace
  • 98 GTI, big changes are coming...
« Reply #11 on: 26 July 2012, 21:38 »
Bare with me as I'm trying to do it on the iPhone...
http://s259.photobucket.com/albums/hh289/flyingtoilet/?action-view¤t=ec928b94.jpg&evt=user_media_share
http://s259.photobucket.com/albums/hh289/flyingtoilet/?action-view¤t=1764a8d9.jpg&evt=user_media_share
Hope that works and you see what I mean...
Gavv8
« Reply #12 on: 26 July 2012, 21:40 »
Your album is set to private, can't view the pics.
Offline MK3 Menace
« Reply #13 on: 26 July 2012, 21:43 »
Ok give me 5 and I'll host them elsewhere...
Offline MK3 Menace
« Reply #14 on: 26 July 2012, 21:44 »
Offline MK3 Menace
« Reply #15 on: 26 July 2012, 21:45 »
That worked, see what I mean? 1 motor and belt driven on the front behind the grille....
Offline trog_nfs
« Reply #16 on: 26 July 2012, 21:47 »
air con cars have twin fans joined together by a belt. They are both switched on when aircon is activated
Offline MK3 Menace
« Reply #17 on: 26 July 2012, 21:48 »
Ah got you, so belted one is air-con, motored one if for engine.
Gavv8
« Reply #18 on: 26 July 2012, 21:48 »
Well i learned something new today.. :embarassed:
Offline trog_nfs
« Reply #19 on: 26 July 2012, 21:58 »
the belted fan is just a slave off the other. If the motored one is running, so is the belted one.
