Author Topic: 3 faults, how do I fix?  (Read 1916 times)
Offline Nino
« on: 25 July 2012, 23:19 »
Hey guys car been alittle strange lately. Put it down to the warm air an stuff but today i decided to run my vag lite and got 3 errors.
17545
 P1137
 Long Term Fuel Trim Add.Fuel,Bank1 System too Rich
17704
 P1296
 Cooling system malfunction
17705
 P1297
 Connection turbocharger - throttle valve pressure hose
Any idea on how these can be fixed? I have had the 17705 error before and both DV (stock one) and MAF where changed for brand new.
Thanks in advance. :)
Current - MK6 GTi Edition 35
Offline Lanfear
Re: 3 faults, how do I fix?
« Reply #1 on: 25 July 2012, 23:59 »
How many miles has your beast done? Depending on milage it could be the water pump. Had same code on my Leon cupra and it cured it :) common problem on these :) turbo could be as little as the hose has come loose so check that before going too far into it :) hope this helps :) Lanf.
Offline Granta Gti
« Reply #2 on: 26 July 2012, 07:09 »
How long does it take for your engine coolant temperature to get to 90? I have has the middle code in the past and the thermostat was stuck open so the car would only get up to 90 in traffic. Changed the thermostat cleared the code and everything was fine
Offline Granta Gti
« Reply #3 on: 26 July 2012, 07:12 »
Thinking about it the first and second code could be related as it will run rich if not up to temperature and the car is telling you over time it has been running too rich
Offline Nino
« Reply #4 on: 26 July 2012, 12:50 »
She is on 118k however at 116k she had Belt & water pump changed :)
Offline Nino
« Reply #5 on: 26 July 2012, 12:51 »
Now that you mention it, My temp hardly EVER hits 90 most of the time its ALWAYS just below 90 or if it does go to 90 it will drop alittle after a while of driving.
Offline barrym381
« Reply #6 on: 26 July 2012, 12:52 »
try a thermostat an temp sensor 1st mate  :smiley:
Offline Dalo Harkin
« Reply #7 on: 26 July 2012, 12:59 »
do the temp sensor first as you dont lose much coolant, thermostat you lose loads.
Offline Nino
« Reply #8 on: 30 July 2012, 12:53 »
Gunna replace both thermo and temp sensor today gunna change coolent as well just so I know its none of these.
Offline Nino
« Reply #9 on: 31 July 2012, 00:36 »
Right changed, termo, coolent and temp sensor, temp now gets to 90 and stays there :) car idels better too, cleared the codes and gunna give it a day or so and see what codes reappear :)
