Author Topic: Fuel pump Relay  (Read 2443 times)
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
Fuel pump Relay
« on: 25 July 2012, 16:34 »
I remember reading somewhere that you are supposed to hear this kick in when you open the drivers door. What does it sound like, as I don't hear anything when I open my drivers door.
how much are they genrally, as the only ones I see on ebay are from £4.99 upto £46.20
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline jamie1989
Re: Fuel pump Relay
« Reply #1 on: 25 July 2012, 18:25 »
Leave the car for abit then try opening the door youl hear a bzzzzzzzzz thats your fuel pump relay  :smiley:
it doesnt do it if have been for a drive get out then straight back.
Im sure its just primin the fuel system
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Re: Fuel pump Relay
« Reply #2 on: 27 July 2012, 09:00 »
Nope, i can't hear any bzzzz sound at all. Is it likely to cause a power loss if it is not working properly? I think I remember reading it controls the injectors?
Offline richw911
Re: Fuel pump Relay
« Reply #3 on: 27 July 2012, 20:45 »
If it is not working it the car wont start.
Re: Fuel pump Relay
« Reply #4 on: 28 July 2012, 07:17 »
Ohh, right, my car has had a few problems not starting since I deleted the hose from the carbon canister pipe to the tip. It turns but won't start, this has only happened a few times though.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Fuel pump Relay
« Reply #5 on: 28 July 2012, 12:46 »
it could also mean your door module isn't registering that it's open...
Offline richw911
Re: Fuel pump Relay
« Reply #6 on: 28 July 2012, 12:57 »
Good point Wez, is there any fault codes? Crank sensor?
Offline Chris.
Re: Fuel pump Relay
« Reply #7 on: 28 July 2012, 13:00 »
Should still do it when keys turned in ignition if door module is faulty...like mine.
Click For Build Thread
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Fuel pump Relay
« Reply #8 on: 28 July 2012, 14:18 »
yarp :afro:
Re: Fuel pump Relay
« Reply #9 on: 28 July 2012, 21:30 »
nope, no fault codes !
