Author Topic: New alloys weired out come??  (Read 1604 times)
Offline Povey
« on: 25 July 2012, 10:11 »
Iv recently lowered my car on coilovers and the alloys iv had on 18" bbs LM reps 8.5j with 5mm spacers both sat flush with the arch both sides which was nice.
Now iv swapped wheels to some 18" RS6 alloys 8j still with 5mm spacers here's the problem one side sits flush with the arch and the other is tucked slightly?!?! Both wheels are the same offset and same specs what's happened? How do I correct this? Iv heard its a common problem
Re: New alloys weired out come??
« Reply #1 on: 25 July 2012, 10:52 »
Maybe one of the alloys is a different offset  :undecided:
Offline DunnDeal12
  • Limited
« Reply #2 on: 25 July 2012, 11:30 »
if your bbs lm's sat flush and the rs6's dont then id say its a problem with your wheels
Offline mcgee9t2
« Reply #3 on: 25 July 2012, 12:05 »
Was going to say quite oftern the rear beam doesent sit compleatly central. theres a thread about it on ukmkivs. and quite oftern lowering makes it more obvious. However i dont see how changing alloys would change how the rear beam is sat
Offline Chris#101
« Reply #4 on: 25 July 2012, 12:29 »
surely the only thing it can be is either your off set is slightly different on your Rs6's or the tyres are different sizes
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline Povey
« Reply #5 on: 25 July 2012, 12:53 »
Iv just been out and checked all the alloys and all exactually the same, all the tyres the same brand and size? I think it might be a case of not noticed before to be honest, and iv read a thread about it looking more obvious after lowering, bud does any one know how to sort it?
Offline AD1.8T
« Reply #6 on: 25 July 2012, 14:42 »
Loosen the 8 axle brackets beat it what ever way needed..... tighten! A ramp would help alot to be fair
Offline mcgee9t2
« Reply #7 on: 25 July 2012, 15:55 »
Yep as said above loosen the rear beam and knock it to the side needed then retighten
Offline cobalt6700
« Reply #8 on: 25 July 2012, 16:16 »
.... Then get the alignment checked!  :rolleyes:
1993 GTI 8v 5dr matt black and green - the 'sh!tball rally car'
1997 GTI 8v 3dr metalic black - the daily driver
2002 3DR 1.8T AUM silver - the new daily
1993 Jeep cherokee 4L - the weapon :D
Offline DunnDeal12
  • Limited
« Reply #9 on: 25 July 2012, 16:35 »
never knew you could get the alignment checked on the rear? thought it was the front only
