IAT effect on requested boost..... The map is KFTARX - IAT correction for maximum specified load
Your ecu will adjust the specified load limit depending on IATs. As IAT's go up, the ecu brings the max boost up a bit so that the driver can't tell that the car is slow in hot weather. It can do this because the stock boost curve is relatively conservative, and there is plenty of headroom. Also, at some point, if IATs go high enough, max specified load is pulled to prevent knock.
Depending on the time of year when i mapped the car (if it was a custom map) hot summers day I will flat line the KFTARX to 1 no corrections) as i set the upper boost limit via other maps, if I am customer tuning in cold weather I will custom adjust the KFTARX map to take in to account the the summer months.
