Author Topic: 2.0 8v GTI Speakers ...  (Read 2223 times)
Offline arran.concept
  • Yellow Colour Concept
« on: 24 July 2012, 15:30 »
could anyone help me and tell me how to get the wee tweaker speakers out from my 3dr golf? theyre in the door card..
 DO i need to remove the door card to replace these or can i remove speaker while card is in place ? thanks
Offline Leebob
  • Jetta Sport TDI cr170,Mk3 Colour Concept 8v
Re: 2.0 8v GTI Speakers ...
« Reply #1 on: 24 July 2012, 23:05 »
Funny you should mention this as i replaced mine only about a week ago,however mine is a 5dr which i did need to remove the door cards to do.Not sure how much different it will be for your 3dr tho.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #2 on: 25 July 2012, 00:28 »
The door card does not need to be removed, simply prise out the inside door handle insert and you will be able to unclip the tweeter. It's a 30 second job.
Offline sharki786
  • GOT BOOST??
« Reply #3 on: 25 July 2012, 02:37 »
his car is e door so the rears doesnt have a handle. I think you unclip them. Have a fiddle about but be gentle am sure you will figure it out
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline kodkod.84
« Reply #4 on: 25 July 2012, 08:17 »
Yes I levered mine out gently with a screwdriver- only to be confronted with no tweeter or cabling!!- same for the front set up, so I only have 4 speakers So that's the next job on the cards...
Offline berry9112
« Reply #5 on: 26 July 2012, 15:13 »
I never had rear speakers in my old 3 door. Only in the dash and front doors. To get them out the rear pull the rear bench up and theres plastic push pins, pull them out, unclip your inner side skirt sill covers, then theres 3 screws holding the B pillar in its clips, undo them and ease the rear panel out. Not hard at all.
You only need a decnt set of components upfront installed well to appreciate sound, heres some inspiration from the build in my old golf
http://www.talkaudio.co.uk/ipb/index.php/topic/324576-mk3-golf-install/page__hl__%20mk3%20%20golf%20%20build
Offline kodkod.84
« Reply #6 on: 26 July 2012, 17:06 »
Yes I have shelved the tweeter idea now- I have 8 speaker grilles 4 front/4 rear but only the lower door card 165mm circular grilles actually had speakers behind them. As my head unit is only 4x55W I have got some new Alpine SXEs that sound a lot better than the ones that were there before and seem really good value.
