Author Topic: how low can u go  (Read 4257 times)
Offline harr1s
  • mk1 caddy and mk2 gti owner
how low can u go
« on: 26 February 2003, 23:14 »
thinking of lowering me golf by about 35-40 mm thing is do i just go for springs or get the whole shebang . ive read on one of the suspension sites that it could be dangerous to change the springs and not the dampers because its possible for the spring to pop out fo place is it true or are they just trying to get you to speend more dosh ...
 Harr1s    ::)
« Last Edit: 01 January 1970, 01:00 by 1055631600 »
Offline stoat
Re: how low can u go
« Reply #1 on: 27 February 2003, 14:08 »
do the whole lot looks better you can boast about it gives a better ride and it is just better
MK3 GTI 8V
biz
« Reply #2 on: 01 April 2003, 16:13 »
It's worth doing the shocks and springs as the ride will be choppy with the standard shockss and they will wear out quicker as they are not designed for lower ride height.
Springs can dislodge with standard shocks, but it is very rare and normally would only occur with lowering springs of minus 60mm or more on standard shocks. More likely it is to be a problem at MOT if the car is jacked in the air and on some cars (V**xhall rear suspension) the springs can fall out, which some MOT places fail the car on.
Biz
« Last Edit: 01 January 1970, 01:00 by -1 »
Offline jv
  • Administrator
« Reply #3 on: 01 April 2003, 16:18 »
"More likely it is to be a problem at MOT if the car is jacked in the air and on some cars (V**xhall rear suspension) the springs can fall out"
:-[ had a Nova that was so low and the rear springs so short that when you jacked it up they would fall out. Had to cable tie them in. Now that is professional!  :-[
jv
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
