Author Topic: I know this will be hard to say but any ideas will help..  (Read 2013 times)
Offline Nino
Hey guys,
Heres the story, about a month ago i had a tiny bump on my front passenger side, damage was only done to the wing and suspension, I had the front passenger whole leg replaced (2nd hand part) brand new wishbone arm, brand new trackrod end and I then had all the tracking sorted.
Since the work was carried out all has been fine upto about 2 days ago I have noticed a Rattle noise coming from the wheel area of the passenger side of the car it sounds like something is loose, now I have had a look and I cannot see anything obviously loose, the noise isn't always there ether I notice it the most while travelling on a straight road at a steady speed the best way I can discribe the noise is a Fluttering rattling noise.
Any ideas on what this could be be guys? I rang the garage that did the work and they cannot look at it till next week and I need my car to get to work  :cry:
Current - MK6 GTi Edition 35
Offline Granta Gti
Re: I know this will be hard to say but any ideas will help..
« Reply #1 on: 24 July 2012, 10:53 »
Pull down on your anti roll bar as there might be play in the droplinks and it does not have to be a bumpy road but just in even and it can set them off
Offline GunnerCP
« Reply #2 on: 24 July 2012, 11:46 »
Check the drivehaft too, make sure all bolts are present and correct.
Offline Nino
« Reply #3 on: 24 July 2012, 12:49 »
Okie dokie i'll check when i get home, a friend of mine mentioned that it may be the strut?
Offline Nino
« Reply #4 on: 25 July 2012, 08:31 »
Ok update: jacked car up took wheel off, checked all bolts on the arm, checked anti roll bar, driveshaft and i cann find anything at all lose, this is puzzling me big time drove down a road today on the way to work and it happened again, it was only a small bump but the fluttering rattle happened again but sounded different like started but slowly faded away  :undecided:
Offline brianpologti
« Reply #5 on: 25 July 2012, 10:02 »
Is it like a tinny rattle ? Could be the brake disc rear cover on the disc
Offline dom
  • Back in a Mk4
« Reply #6 on: 25 July 2012, 13:56 »
Heatshield for the exhaust?
Offline Nino
« Reply #7 on: 25 July 2012, 19:51 »
Kinda the rattle starts loud then gets quieter, that cover isit the small thin piece of metal at the back of the disc kinda resembles a heatshield of somekind?
Offline Nino
« Reply #8 on: 25 July 2012, 19:52 »
Don't think it could be that buddy as its defo coming from the passenger side wheel section.
Offline Nino
« Reply #9 on: 31 July 2012, 00:39 »
Ok while changing my thermo today i noticed that the bottom of my rad was loose and i can freely move it abit. . . Could this be it? However the noise defo seems althou its on the passenger side.
