Author Topic: Best pads for vr6?  (Read 1143 times)
Offline jnufcuk
Best pads for vr6?
« on: 23 July 2012, 20:56 »
Every time I brake I can hear a rubbing type of sounds coming from the back wheels. So take it it must be the pads can't think of anything else?
What are the best ones to use ? Also what size are they? It has grooved discs atm but don't know if they're standard size or bigger? :undecided:
Offline leigh_harty
  • Audi AGU
Re: Best pads for vr6?
« Reply #1 on: 23 July 2012, 21:11 »
judging from your pics in dub rides you have 288mm brake (metal clip running across calliper)
Personally i run ebc discs and green stuffs - Do what i want although brake fade does appear after some trashing but 95% of the time they is reet  :wink:
Go with solid discs - drilled discs can crack with the constant heat exchange but you'll probably never use them enough to do that
Mintex are highly rated too
Dont lose your dinosaur!
Offline leigh_harty
  • Audi AGU
« Reply #2 on: 23 July 2012, 21:12 »
Im an idiot you was referring to the rears  :grin: Standard size weather drilled/grooved/both/none  :smiley:
226mm x 10mm
« Last Edit: 23 July 2012, 21:14 by leigh_harty »
« Reply #3 on: 23 July 2012, 23:56 »
Just go for a good quality Mintex, Ferodo or Pagid
