Author Topic: Bonnet Wont Close  (Read 2223 times)
Offline tigerj360
Bonnet Wont Close
« on: 23 July 2012, 14:29 »
Hi guys, was fitting my BMC CDA the other day and thats all great!  :smiley:
However when i went to close the bonnet, it just wont shut! It latches on the first lock but wont push down in to the second lock  :angry:
I've had a read around but cant find a solution, was just wondering if anyone had any ideas or had encountered this before?
Jon
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: Bonnet Wont Close
« Reply #1 on: 23 July 2012, 14:32 »
Take it back up and manually operate the mechanism to see if it is working. Perhaps the CDA is stopping it?  :undecided:
Offline tigerj360
« Reply #2 on: 23 July 2012, 14:56 »
Sorry should have mentioned that. Theres nothing stopping it from closing, as I can push down both sides and they sit flush. Its just the middle at the front that wont push down in to the lock.
Also I've tried using a screwdriver as a pretend hook and that wont lock in even when I push it all the way down. Which is strange as the parts all move albeit not very easily, but enough to move with force which I can imagine is how they should be?
Offline bobbarley
  • I'm kind of a big deal...
« Reply #3 on: 23 July 2012, 15:26 »
Slam it a lot harder.
Offline km
« Reply #4 on: 23 July 2012, 15:52 »
after taking my bumper off to fit my intercooler, my bonnet wouldn't shut unless with some force, but it's fine now.
don't be afraid to slam it  :grin:
Offline Dalo Harkin
« Reply #5 on: 23 July 2012, 15:55 »
you sure nothing has fell down, I put my tools near the catch when working on the front, you sure nothing fell down when you were fitting the CDA
Offline GunnerCP
« Reply #6 on: 23 July 2012, 16:09 »
I've had this problem, a good hard slam secured the bonnet but then it sat too low compared to the wings do I need to move he catch up by a few mm and all should then be good :)
Offline tigerj360
« Reply #7 on: 23 July 2012, 17:16 »
I'll try giving it a massive slam when I get in and hope that works. If anything goes wrong I'm blaming you guys!  :grin:
Nothing dropped when fitting the CDA, so I have no idea what else it could be other than replacing the catch!
Offline tigerj360
« Reply #8 on: 23 July 2012, 19:00 »
Well slamming it didn't work looks like a new catch is needed!  :grin:
Offline golf-sib
  • Турботазик
« Reply #9 on: 23 July 2012, 19:31 »
I've seen a few of these fail on mk4's I got blamed for breaking one as well, when I'm sure it was just bad luck.
Could be worse, on some BMW's its a nightmare to sort out when the bonnet lock fails! You can try and cause the mechanism to click into the second catch point with a screwdriver but it doesn't always work depending on how bad the lock has gone.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
