Author Topic: R32 Golf enhancement detail  (Read 4133 times)
Offline butler2.8i
« on: 22 July 2012, 15:59 »
An enhancement detail on a stunning R32 Golf which is fitted with a plush air suspension system and Image DM 19” Alloys
Products and equipment used
Uber microfiber towels
Chemical guy’s woolly mammoth drying towel
3m yellow pads 150mm 75 mm
140 mm Glazing pads
Halogen site lights
Makita rotary polisher
DA Polisher
Scholl s17+
Prima Amigo
Swissvax Best Of Show
Carpro eraser
3m masking tape
Meguiars APC
Costco microfibre towels
Meguiars hyper dressing
Valet pro citrus bling
Bilt Hamber AutoWheels
Valet Pro PH neutral Snowfoam
Valet pro tyre dressing
AMDetails AMbubbles
Bilt Hamber clay bar
Autosmart Tardis
Various brushes
Kranzle pressure washer
Carpro Sheepskin wash mitt
Carpro Dlux
Noodle wash mitt
Carpro Lambs wool wash mitt
Poorboys microfibre clothes
Uber buffing clothes
Autobrite Snow foam gun
Chemical guys Jetseal 109
Autobrite Repel
Auto Finesse Mecury Metal Polish
00 grade wire wool
Some photos of the car before I start
The car was then given its first coat of snow foam whilst this was dwelling I went round the car using APC in a foaming head bottle cleaning the fuel filler area and various gaps and grills. The snowfoam was then blasted off with the pressure washer, and then the car was given another coat of the same mix snowfoam and the car was washed using the 2 bucket method with grit guards in both buckets and a Carpro lambswool wash mitt.
The car was then rinsed off using an open ended hose and I then went round the car with Tardis which was left to go to work before being wiped down with microfibre clothes. The car was then given a coat of Ironx again left to do its stuff before the car was washed doing using the pressure washer.
The car was clayed using citrus bling and water mix (10 to 1) and a Bilt hamber soft clay bar which helped to pull more contaminates from the paint work it was then rewashed using the same method and dried using the woolly mammoth.
The arches where next and they where sprayed with APC and cleaned using various brushes and a noodle wash mitt. They where then sprayed with Tardis which was left do its stuff whilst I moved onto the next arch before going back and being wiped down with a microfibre cloth. The engine bay was sprayed with APC and left do dwell before being given a tickle with a soft detailing brush before being rinsed with the pressure washer and dressed with Megs Hyper dressing.
A few 50/50 shots using my site lights
I then taped the car up and went round with various yellow 3m pads and Scholl s17+ polish, each panel was given a wipe down with carpro eraser after polishing to check finish and remove any polishing oils.
I then went round the car and applied a coat of Prima Amigo using the DA and the lake county pad which was left before being buffed using Uber buffing towels.
The car was given 2 coats of the Swissvax Best Of Show wax leaving wax to bond for 30min and approx 60min between each coat again buffed using Uber buffing towels, between coats of wax the underside of the bonnet was given a couple of coats of Prima Amigo
The plastic trim was dressed using Carpro Dlux which is a cracking product which a little goes a long way and gives a stunning finish.
After this I cleaned the glass and gave them all  2 coats of Autobrite repel and also gave the arches coat of hyper dressing and dressed the tyres using the Valet pro tyre dressing. Alloys sealed using 2 coats of  Chemical guys Jetseal 109
Exhaust`s where cleaned up using Auto Finesse metal polish and 00 grade wire wool
Some for the beading fans
Offline butler2.8i
Re: R32 Golf enhancement detail
« Reply #1 on: 22 July 2012, 16:00 »
Air tank and pipe`s given a coat of Prima Amigo
Finished shots
Here`s a link to my facebook page
http://www.facebook.com/#!/NorthEastCarCareUK?notif_t=page_new_likes
jockgti
« Reply #2 on: 22 July 2012, 21:06 »
looks great mate wish my black one looked that good
Offline Mr GTD
« Reply #3 on: 22 July 2012, 21:59 »
That looks the nuts, great job...black must be one of te best when all gleaming it's just a shame it doesnt stay like that for long...very :cool: pal...
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #4 on: 23 July 2012, 14:39 »
Another cracking job mate!!  :cool:
Bet the air ride made tackling the arches a breeze  :rolleyes: :grin:
How long does a job like that take you? You seem to be smashing the cars at the mo, busy time with all the shows I bet?  :smiley:
Offline butler2.8i
« Reply #5 on: 23 July 2012, 14:52 »
Cheers Guys :cool:
Offline butler2.8i
« Reply #6 on: 23 July 2012, 15:07 »
Cheers matey, i`m loving the air ride system as it was a giggle being able to raise and lower it from the remote.
I can turn a car round in 10 to 12hrs but i usually take a little longer because of my OCD lol
Offline Dan J
« Reply #7 on: 23 July 2012, 18:28 »
Good work Shaun, very nice R32.
Offline Murrayedition35
« Reply #8 on: 24 July 2012, 22:33 »
Really nice job... :smiley:
well worth the hard work...
Offline butler2.8i
« Reply #9 on: 24 July 2012, 23:16 »
Cheers Guys :cool:
