Golf mk4
Wazzzer
oil from sump bolt
Topic: oil from sump bolt (Read 810 times)
Dalo Harkin
oil from sump bolt
22 July 2012, 08:20 »
Losing oil from sump bolt, dont want to tighten anymore incase i knacker the thread.
any ideas
seen its quite common....
ARZ K03s, Oettinger Side Skirts, R32 front, Carbon stage 2, Forge 007p (yellow spring), Forge Actuator (yellow spring), Pipercross panel filter with DSG parts, N249 and N112 deleted, SAI deleted, Carbon canister deleted, Rear wiper deleted, Long Life turbo back custom exhaust with 200 cell sports cat, VR6/G60 clutch kit, Creation Motorsport TIP, Catch can, 'Wellycooler', K04 charge pipe, S3 ported inlet manifold - looks pretty standard on the outside though
CL-SID
Re: oil from sump bolt
22 July 2012, 09:31 »
Get a new nut and washer...
Never changed one on mk3 but normally the washer wears allowing oil to drip out. Sometimes they are a compression washer and this fails after being removed and refitted all the time.
I want to be adored! - Oh, and I need one or two golf bits.
Hoggy
Here all the time
Mk4 GT TDI 150.
22 July 2012, 10:48 »
I would be suprised uf it is the drain plug thats jiggered, the mk4 ones are very good quality even though the stealers will give you a new one with a filter, more likely to be damaged threads on the sump, common fault.
Golf mk4
Wazzzer
oil from sump bolt
