Author Topic: What you reckon?... New Hoops.. Change Colour or Leave em!  (Read 3146 times)
Offline lowry_uk
Just picked these Hopps up yesterday and fitted today.
8J front and 9J rear with a nice dish
Not sure about the Gold inner..
Whats your thoughts
Any comments are welcome
Golf MK4 PD130
18" Cades Tyrus Alloys after a Swap for some 3SDM's
Offline s-l-i-x
  • Golf MK4 1.8T AGU
Slamming it more will make it look  :cool:
Offline lowry_uk
Im gunna get some coilys again soon, i think
Just to harsh to drive when its my daily lol
Golf MK4 PD130
Offline cullygti
needs to be slammed
heres my daily  :lipsrsealed:
Offline s-l-i-x
  • Golf MK4 1.8T AGU
Also put 15/20mm spacers on the rear  :cool:
Lowering and spacers needed but they look ok in Gold.
Offline Dalo Harkin
Cully how do you work on your car when its so low, mine hasnt  een lowered yet but has skirts and can only just get a jack under it now
Offline lowry_uk
Ok as to lowering what's the best ride comfort coilys or shortened dampers and springs?
Can anybody recommend me some cheap but good spacers.. And a noob question
If I got hubcentric spacers do I need to change my wheel bolts to longer ones or are these supplied or do standard bolts bolt into the spacer??
Golf MK4 PD130
Offline s-l-i-x
  • Golf MK4 1.8T AGU
Get coilies  :grin: if you get springs, you will only regret it and want to go lower at a later date, happens to everyone on here! Plus those wheels would only look good on coilies, springs wont go low enough. Plus with the coilies you can fine adjust the height whenever you want, up or down by mm's at a time.
And hubcentric spacers bolt to your hub, then you bolt your wheel to the spacer. So 10 sets of bolts per wheel if that makes sense.
Offline cullygti
bloody hard work i use 2 jacks smaller one to lift it high enough to fit the bigger one under
