Author Topic: car just passed mot-exhaust emissions running rich..  (Read 2075 times)
Offline Jasikasisback
ok i am stumped as to why the fuel mixture is running rich..i have changed the exhaust, injection flange mount (throttle body looks ok and plugs look ok), rocker cover gasket and breather/vacuum hoses...no idea why still running rich..
i was wondering if a clogged fuel filter could cause this problem.....and what other ideas people have..
it is causing lumpy idling when i stop...but ok in neutral...fuel economy is poor...:(
at least it passed the mot...no advisories...
Offline itavaltalainen
Re: car just passed mot-exhaust emissions running rich..
« Reply #1 on: 21 July 2012, 22:37 »
any fault codes stored in ecu? which engine (code) is it?
maybe temp sensor?
Offline nolandubholmes
« Reply #2 on: 21 July 2012, 22:49 »
Any air leaks ?? Vac leaks plus I'd get it checked for fault codes check some live data if poss and then go from there but as above if ur coolant temps giving a mad reading of freezing cold it will fuel too much
aum no spec as no matter what i do il never be happy
Offline mrsaunders
« Reply #3 on: 23 July 2012, 10:43 »
maf? lambda? could be a number of things
« Reply #4 on: 23 July 2012, 14:11 »
temp needle works ok...at least it appears to be ok...no leaks that i can find...or that the MOT place noticed..
runs fine on the motorway...but very rich elsewhere...
no fault codes found last time i checked..but maybe should check again at my friends...
but for a 17 year old car...what can you expect?
« Reply #5 on: 23 July 2012, 17:25 »
temp needle working ok does not say anything, that uses a different sensor than ecu (albeit both sensors being in the same housing).
read temp with vag com to see if it's that.
Offline javalin
« Reply #6 on: 25 July 2012, 10:06 »
yup +1, most common cause is faulty temp sensor.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
« Reply #7 on: 27 July 2012, 09:29 »
Ive got the same engine as you do. Maybe you can send me a picture of where it is located or explain where it is?
« Reply #8 on: 28 July 2012, 11:09 »
Before replacing measure pins 1+3 and 2+4 at totally cold engine (leave over night) and when it's warm (when it shows 80 - as when speedo shows 90 its anywhere between 80 and 100) and compare values with the diagram.
The diagram covers only pins 1+3 but 2+4 should give similar response, just measured a spare one I have still from my old Golf. Resistance between pins 2 and 4 is approx half of what it is between 1 and 3.
Here's the image with location of sensor:
« Last Edit: 28 July 2012, 13:31 by itavaltalainen »
