Author Topic: Willing member in West Midlands to do timing on my 8v GTI? :D  (Read 984 times)
Offline OffEdge
Hi all,
As above really, and sorry about all my posts lol! iv given up trying to do my timing, i do think it is out, but wondering if anyone would be willing to pop round to check it, and change it if it is wrong? ill pay and supply drinks :P
Thanks
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Just out of interest... what timing are you trying to do? because in theory you don't need to time up the 8v engine ignition timing,  when you do the timing belt, you need to line up the crank with the intermediate shaft, and set the camshaft,  you take the dizzy cap off, and ensure the rotor arm points to the little notch, then that it, as long as its all set to the base marks, the rest of the ignition timing is automatic.  You cant time these up with a gun, it will just keep trying to correct its self.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline OffEdge
Basically, I had the car and it wasn't running right, so I had a look at the engine timing, and it looked to be a tooth out, so I timed it up to what I thought was correct, then had a look at the ignition timing and it was out giving me a 5000rpm limiter, so I adjusted that, but atill have the limiter, just want someone to have a look for me to ensure the engine timing is correct, and if not to put it right lol then I can check the ignition timing again,
Thanks
Offline Deano2711
  • 1992 VR6
Dodgy hall sender will also give you the 5k limit Bud
