Author Topic: 1.8t conversion  (Read 8508 times)
Offline leigh_harty
  • Audi AGU
Re: 1.8t convertion
« Reply #20 on: 21 July 2012, 20:58 »
I'll be looking out for the ' help my engines fallen out' thread   :grin:
Or the - can i upgrade duck tape to zip tie mounts.
Dont lose your dinosaur!
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: 1.8t convertion
« Reply #21 on: 21 July 2012, 23:22 »
way too cheap
anyhow
MK4 box will fit (as i have a bespoke box in my car now but it is based on a MK4 item)
MK4 driveshafts only fit on the passenger side, drivers side (long side won't fit as its longer on mk4 4)  - I also know this as this is what i run on my car. MK4 GTI on passenger side, drivers side is MK3 16v
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline Shady Pioneer
  • graphic designer.
Re: 1.8t convertion
« Reply #22 on: 21 July 2012, 23:28 »
What's a convertion? I'm guessing they are offering a different service to the 1.8T conversion you're talking about. :grin:
Anyway, seems way too cheap, sure they aren't just gonna stick a 16v engine in and a 20vt cover to go over the top?
Offline Gash
Re: 1.8t conversion
« Reply #23 on: 22 July 2012, 15:42 »
imhaving mine done for 300 labour and that includes, taking mine out, cleaning engine bay, putting new in and all the wiring loom.
engine was 300
intercooler, ecu lightened flywheel etc etc about 200-300 so mine under a grand just! lol
Offline CJA321
Re: 1.8t conversion
« Reply #24 on: 22 July 2012, 16:24 »
engine was 300
I cant honestly see how you can get it done that cheap. If your starting with a 16v would be cheaper obv. How much was your exhaust and things?
Offline Gash
Re: 1.8t conversion
« Reply #25 on: 22 July 2012, 16:28 »
mine was a 16v so hense why cheaper.
my mate whos doing it for me did a conversion himself into a mk2 golf and worked with vws for 10 years so i know and trust him for it to work.
all the things you need...
mounts-got
exhaust-got
gearbox- got
ecu (managed to find a unlocked/remapped for £95)
downpipe he had - 50
lightened flywheel - 50
intercooler - 20
piping - 70
so 890 roughyl :D
Offline CJA321
Re: 1.8t conversion
« Reply #26 on: 22 July 2012, 16:35 »
mounts-got
exhaust-got
gearbox- got
intercooler - 20
piping - 70
so 890 roughyl :D
See mines cost alot more cause iv had to buy all that haha!!
Offline Gash
Re: 1.8t conversion
« Reply #27 on: 22 July 2012, 16:36 »
lucky i guess! hah
plus iv got 288mm brakes and full 2.5" exhaust. lucky i guess :D
Offline F17BAD
Re: 1.8t conversion
« Reply #28 on: 22 July 2012, 20:49 »
what about TIP ?  approx £100, diverter £100 (unless u get a copy or use bothe the standard TIP and diverter - bab tho)) Air filter £100 (unless u get something sh!te and restrictive?
VR6 clutch?  could use your old valve one but thats just cutting big corners IMO
New engine mounts ?  again cutting massive corners using old ones
New stretch bolts for flywheel ?  around £30 new bolts for clutch £can remember
All the new gaskets for engine manifold, turbo TB etc etc
New service parts, decent oil, filter, Coolant (G12 plus plus) non of this is cheap - appros £100 their
Cambelt ?   Waterpump, ? tensioners ?, Aux belt ?
loads of bits off your list you have missed unless you are cutting huge corners which i would not personally do
 :smiley:
Offline Gash
Re: 1.8t conversion
« Reply #29 on: 22 July 2012, 20:54 »
dont count the service bits seeing as they would be needed anyways.
i just meant the big things
