Author Topic: URGENT!! Need timing help like now lol!  (Read 3186 times)
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: URGENT!! Need timing help like now lol!
« Reply #10 on: 20 July 2012, 10:27 »
You need to screw the green bung out the gearbox as that will reveal a point on the gearbox casing which lines up with the mark on the flywheel as its the most accurate way of gaining tdc and if the flywheel aint lined up correctly nothing else will, make sure both OT marks line up on tha cam shaft and the mark on the dizzy lines up dead centre with the rotor arm. This is how I did it anyway to loose the 5000rpm limit and clear the fault code.
Offline OffEdge
« Reply #11 on: 21 July 2012, 00:51 »
Thanks for that mate, I appreciate it, how does the green thing unscrew? Just chisel it round or? And ill make sure I like up the OT markings not the arrows lol!
Offline Gti_Jamo
« Reply #12 on: 25 July 2012, 10:43 »
Yeah chisel it out but try not to break bits off that may drop inside...it will more then likey break anyway but new ones can be had from the dealers for about £4.
