Author Topic: Cannot turn alarm off, any solutions?  (Read 3909 times)
Offline staddon
« on: 04 October 2003, 13:01 »
Having a big problem with a Golf Gti(97 P reg), and the alarm.
Took out existing radio and put new one in, whilst putting new one in
I disconnected the battery, before I reconnected the battery i had left the ignition on, when the battery was reconnected, the alarm started, and I have not been able to turn it off by any means since.
Anyone got any solutions , thanks.
« Last Edit: 04 October 2003, 13:03 by staddon »
golfvr6
Re:Cannot turn alarm off, any solutions?
« Reply #1 on: 04 October 2003, 13:19 »
A similar thing happened to me when i took my starter motor off on my vr6. I was told the only solution was to send the alarm ecu off and get it re-set. So i called out the RAC and got them to cut the wires!
Offline staddon
« Reply #2 on: 04 October 2003, 13:40 »
The alarm  has stopped going off now, and the car turns over, but will not start, radio etc all function, any idea what the problem is now, is it immobilised?
« Last Edit: 04 October 2003, 13:41 by staddon »
golfvr6
« Reply #3 on: 04 October 2003, 14:13 »
The alarm will have an immobiliser that usually cuts off fuel and ignition.
Offline modulater
« Reply #4 on: 05 October 2003, 23:36 »
Posted by: golfvr6  Posted on: October 04, 2003, 14:13
Quote
Indeed VR6 is on the nail as usual, alarms are great when they work but a pin in the arse when they go wrong. I would seek the advice of an auto electrician who may be able to sort the alarm out.
I would imagine the alarm has gone pear shaped and may be worth while getting it torn out and a new one put in its place.
« Last Edit: 05 October 2003, 23:39 by modulater »
Offline Pimpster
« Reply #5 on: 06 October 2003, 10:44 »
a big hammer....
Offline modulater
« Reply #6 on: 06 October 2003, 22:51 »
Or indeed as pimpster suggests, peter sutcliffes favourite.
The hammer.
Offline VentoBoy
« Reply #7 on: 12 October 2003, 21:20 »
Staddon, can I borrow your thread for a second?
I just removed the fuse from my alarm (long story, lets just say getting fed up of flat batteries).
Don't have a keyfob, car still starts okay.
Back of alarm says, "Easy Fit Alarm", is this the factory fit or is it something someone's bolted on afterwards?
