Author Topic: Suggestions for thick insulated wire for testing Fans & AC Compressor - any idea  (Read 1789 times)
Offline MrJonSavage
Hi.
Gonna be testing my AirCon Compressor & Fans to see if they are fried (as AC Compressor not kicking in & yes have read most of the forum posts re this!).
In these posts they say to put 12V across the relavent terminals from your car battery to test them which is all well & good BUT they say you need some thick a*s insulated wire to do this as they draw quite a hefty current (amperage - 30-40A fuse protectioin on battery so confirms this) and tend to melt the insulated wire within seconds so,
(1) Anyone suggest what wire & maybe in a practical sense where to get?
(2) I could use my battery charger & clamp two probes on end of clasps then juice it up (though most chargers only give out up to about 20A so this may not be enough to 'check for life' in these bits if they require higher Amps than the charger can give?)?
(3) Any other ways to put the right voltage/current across.
Please, no jokers or glib comments, just bare facts everyone, ta!
Offline rio_gti
Have u checked the fuses ontop of the battery??
When it's turned on five them a wiggle it's one of the 3 green ones
Offline Wazzzer
  • Golf GTI 1.8T AGU
how about household electrical wire....
Offline harlemex
auto subwoofer cable and in-line fuse off ebay.
Halfords sellsmall rolls of wire, look for the 30amp rated wire that will be fine.
Offline danny_p
for testing   - some wire will do  anything bigger than 1mm   it may get a bit warm after a while but who cares,   find a nearby mk3  and rip some loom out of it
all the VW's have gone bar 1.
