Author Topic: Tiger seal removal?  (Read 3284 times)
Offline 67buggers
Tiger seal removal?
« on: 19 July 2012, 15:11 »
What can i use to remove tiger seal from my paint work?
I fix iPhone's and iPod's, I can fix most faults call me on 07811344816 for a quote
Offline LazyLunatic
  • MK3 20VT Project
Re: Tiger seal removal?
« Reply #1 on: 19 July 2012, 17:47 »
Luck.
Nah, you can use a rubber wheel attachment on an angle grinder :)
Offline 67buggers
« Reply #2 on: 19 July 2012, 18:39 »
Neither of which i have..... Was hoping the answer would be thinners!
Offline LazyLunatic
  • MK3 20VT Project
« Reply #3 on: 19 July 2012, 19:23 »
You can but angle grinder and rubber wheel would be much easier. Rubber wheel's arent too expensive and a grinder is a good investment and aren't too expensive either!
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #4 on: 20 July 2012, 19:34 »
It depends on how thick it is, sometimes it can just pull off in chunks, try some WD40 and wrap some cloth around your finger, give it a good soaking, and try and work the WD under the sealer
Don't use thinners, it could affect your paint
Thom
Offline Mr Blue
« Reply #5 on: 20 July 2012, 20:28 »
I used Autosmart Tardis. Didn't come off easy but no paint damage.
Offline 67buggers
« Reply #6 on: 23 July 2012, 08:17 »
Nice one lads I'll give it a go
VW BUSH
« Reply #7 on: 23 July 2012, 12:43 »
I used WD40 a rag round my finger to rub off loose and work the paraffin into the resin, a plastic filler spatula could then be used to pry off the rest.
Don rush it or you will feck the paint.
After I got it off i used T cut to polish off the marks and shine.
