Author Topic: Oil level/pressure buzzer  (Read 1626 times)
Offline D Squared
« on: 19 July 2012, 06:48 »
Went round a roundabout last night quite enthusiastically (as you do), with the indicator on, and at the same time i had a loud buzzer chirping at me...sounded like the sort of buzzer you associate with having a towbar on, when indicating...
turns out that a buzzer sounds when the engine is either low on oil or low level and above 2000rpm.....although oil light wasn't on..
bit clever really for an old Golf
have been putting off topping up the oil as needed an oil change....have now changed oil and filter....187k and still going..!!  :grin:
MK3-MK5- Now MK7 GTi
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Oil level/pressure buzzer
« Reply #1 on: 19 July 2012, 10:28 »
The buzzer is a low pressure warning more than likely brought on by a very low oil level been swooshed to one side if the sump when cornering with force. You can get baffled sump pans to help prevent this happening.
You should never put off topping up the oil regardless of service interval.
Offline trog_nfs
« Reply #2 on: 19 July 2012, 11:43 »
I get this one at work so many times, its so stupid I just want to hit people  :grin:
Offline D Squared
« Reply #3 on: 19 July 2012, 12:24 »
yeah i know it was very lazy..and i should know better as i work in Automotive industry too...!
no harm done this time..!
« Reply #4 on: 19 July 2012, 20:52 »
You were lucky, never a good idea to run low on oil.
