Author Topic: AUM Big Turbo  (Read 4278 times)
Offline Chris.
AUM Big Turbo
« on: 18 July 2012, 23:04 »
Im going to be putting a big turbo (t04e) onto a AGU lump running AUM management (ME7.5)
I have a few questions I need to know in regards to fuelling and sensors such as the MAF.
What size injectors do I need?  Im going to be running around 400-450bhp so nice to have a bit overhead so they not running flat out at top duty cycle.
Am I going to need a Wahlbro 255lph inline fuel pump?  I currently have a uprated intake pump but not sure what LPH it flows.
What size MAF housing do I need?  Is there options of MAFless with me7.5 or does it cause too much hassle etc.
3" straight through exhaust?  Going to see if I can keep my remus backbox as I love the sound of it....but I guess it will be totally different sound with a extra 200bhp pushed through it.
Engine spec is going to be:  82mm JE 9.25CR pistons, IE forged rods, Supertech valvetrain, AGU head, AGU inlet, potentially IE street/drag cams, custom manifold with turbo above gearbox, T04e turbo, short 2.5" IC piping, new sensors and coilpacks.
Any advice would be appreciated :D
Click For Build Thread
Offline DunnDeal12
  • Limited
Re: AUM Big Turbo
« Reply #1 on: 20 July 2012, 15:04 »
what about custom inlet manifold with throttle body on the right?
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: AUM Big Turbo
« Reply #2 on: 20 July 2012, 17:56 »
Cannot wait for this  :smiley:
400-450 hp going through the front wheels...May I ask what you got planned for the gear box/clutch/LSD? etc  :smiley:
Offline westallc
Re: AUM Big Turbo
« Reply #3 on: 20 July 2012, 22:32 »
cams will be hard to come by at the moment there on back order
going to need bigger fuel pump immo bosch 044 and a swirl pot will surfice
what handling and braking mods have you done??? lsd etc etc
630cc siemens high impedance injectors will be fine
you can run either 3 inch maf or mafless but best to spk to the mapper doing the work they will suggest the best route
is the engine built yet
Offline Chris.
Re: AUM Big Turbo
« Reply #4 on: 20 July 2012, 23:17 »
Not yet, on building it.
No idea what clutch, but will be a decent one.
No LSD for now, probably end up going 4wd in the distant future.
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: AUM Big Turbo
« Reply #5 on: 21 July 2012, 23:04 »
sounds like a cool build but...
FWD and No LSD or 4WD with 400/450 bhp
 :grin:
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline westallc
Re: AUM Big Turbo
« Reply #6 on: 22 July 2012, 09:23 »
400+ bhp with no lsd !!!! pointless imo
Offline Chris.
Re: AUM Big Turbo
« Reply #7 on: 22 July 2012, 13:45 »
James who has a AGU t04e manages to run 12s at santa pod with no LSD, not the biggest amount of wheelspin.
Remember its how you drive it.
Offline F17BAD
Re: AUM Big Turbo
« Reply #8 on: 22 July 2012, 21:19 »
hear you.. but the LSD in mine made more than a huge difference and that was with less than 300bhp
ill be running around 350 hp in the next few days with my new set up and i think that will be the limit for my shell and set up before it becomes non usable power..
no point having it if u can't use it to full advantage (like been polite with the peddle )
look forward to your build tho mate, sounds good
