Golf mk3
hardmonkeys
I've cammed my 8v and need timing help
Topic: I've cammed my 8v and need timing help (Read 2199 times)
tweed
Forum addict
18 July 2012, 22:06 »
Done it to the guild on here. Turned it over by hand, yep all good. Started it up and I have lumpy idle. Let it sit for a bit then held it at 2000rpm for a while. Took it out taking it easy for few miles then decided to let it rev up and.......
5000rpm safe limit
Defo out as well because it don't feel right.
A little help on how to time it back up please
Last Edit: 18 July 2012, 23:17 by tweed
Untitled
by
tweedub
, on Flickr
berry9112
Re: I've cammed my 8v
18 July 2012, 22:21 »
The idle will be a little lumpy with cams, because of the greater amount of air/fuel. Take the plugs out and check top dead center on the first firing cyclinder (cant remember firing cycle, 1 3 2 4??) wont be hard to find.
Let us know how it goes
tweed
Forum addict
18 July 2012, 22:33 »
ain't it easier with the timing marks on crank and cam pulley? Its only out a tooth. Just don't know what way.
Untitled
by
tweedub
, on Flickr
tweed
Forum addict
18 July 2012, 22:50 »
right had a little read and your right. So set tdc on number one, slip belt off, turn cam to its mark then put it back on.
sound about right?
Untitled
by
tweedub
, on Flickr
CJA321
18 July 2012, 22:52 »
Thats the way yeah, take plug out obv
MK3 GTI 20vt project
http://www.golfgtiforum.co.uk/index.php?topic=230628.0
tweed
Forum addict
18 July 2012, 22:58 »
I will use a pencil
Untitled
by
tweedub
, on Flickr
CJA321
Reply #6 on:
18 July 2012, 23:04 »
Yeah thats perfect, i use a thin screwdriver personally
berry9112
Re: I've cammed my 8v and need timing help
Reply #7 on:
19 July 2012, 13:03 »
sounds about right, luckly last time i replaced my cam belt the guy before had marked it up good and proper, tip-ex the lot aha. Still worth double checking though. Got it running right now?
VW BUSH
Guest
Reply #8 on:
19 July 2012, 13:05 »
Normally the inter shaft is out which puts the dizzy out, check line up on dizzy with Cam and N1 in tdc as well as checking the top and bottom end for correct sequence.
Inter shaft moves under its own weight, which is a fecker if you dont have three hands
AGG/ADY engines will throw a fault on the ECU if the cam is too aggressive, what are the specs?
tweed
Forum addict
Reply #9 on:
19 July 2012, 13:22 »
Cool cheers I'll check that too then. No not yet, gonna get on it when I'm back from work. worst come to worse I'm off work tomo and will give it to someone with experience
Untitled
by
tweedub
, on Flickr
Golf mk3
hardmonkeys
