Author Topic: MOT tomorrow...  (Read 5115 times)
Offline trog_nfs
Re: MOT tomorrow...
« Reply #10 on: 18 July 2012, 17:55 »
Failed on a couple things, excessive corrosion on rear brake pipes, and a couple other things. f**k.
Oh well, getting all sorted nect week so it'll be okay then.
I've had this one every year. This year i rubbed the pipes with a bit of wet and dry and slapped on the hammerite. Under the sh!t they were like new though
Offline Screech16v
  • MK3 20vt AGU
Re: MOT tomorrow...
« Reply #11 on: 18 July 2012, 18:32 »
So youve mot`d your car and its failed,does this mean you now have no mot until it passes,as the fail voids any remaining mot? thought i heard something about it called the mot trap  :shocked:
Gavv8
Re: MOT tomorrow...
« Reply #12 on: 18 July 2012, 18:36 »
Same here, pressure washed them then sprayed them with paraffin/diesel.
Offline Shady Pioneer
  • graphic designer.
Re: MOT tomorrow...
« Reply #13 on: 18 July 2012, 20:01 »
I don't think so, as my current MOT isn't up until 7th Augist and they said even if it fails I still have up until then. Although I will check this now.
  • graphic designer.
Re: MOT tomorrow...
« Reply #14 on: 18 July 2012, 20:09 »
Just found this:
http://forums.overclockers.co.uk/showthread.php?t=18421503
Appears its a grey area, guess I'll be leaving the car until next week then.
Offline Seanl
Re: MOT tomorrow...
« Reply #15 on: 18 July 2012, 20:26 »
This. I did it too after getting an advisory one year. Did this the following year and flew through without a mention. As long as the unions are in a reasonable state, it should be fine mate.
Offline SoundillusioN
Re: MOT tomorrow...
« Reply #16 on: 19 July 2012, 09:26 »
Gutted, ah well, not a terrible fail though.  were the other bits minor?
Offline Len
Re: MOT tomorrow...
« Reply #17 on: 19 July 2012, 12:45 »
They may not be minor as Shady has failed to mention them!
Or they are stupid ones he dont want to admit, like no water in the washers! :laugh: :laugh: :laugh:
www.sas.org.uk
www.the-ace.org.uk
  • graphic designer.
Re: MOT tomorrow...
« Reply #18 on: 19 July 2012, 13:07 »
No the minor ones were chip in windscreen and something else.
I made sure all obvious things were done such as washer fluid.  :grin:
How much work is involved with replacing brake pipes? And how much roughly should I be letting a garage charge for the job?
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: MOT tomorrow...
« Reply #19 on: 19 July 2012, 15:33 »
Likewise, failed last year got a second opinion and rubbed them down then it went straight through on retest. This year I got an advisory on them. When I get the chance il clean then up properly and hammerite them as well.
