Author Topic: Another coolant light issue :)  (Read 1523 times)
Offline Jimmyrallye
  • 20vt goodness
« on: 17 July 2012, 20:33 »
Sinse ive had my golf (2 months) my coolant light would flicker on and off every now and then .. Starting from today its on as soon as i start the car from cold and even stayed on earliar after i took tge key out the ignition ???? Have done all checks and everything seems fine fans cut in ect also had a new rad no leaks ... Could it be my water pump on its way out as well ? Thanks jimmy :)
Offline JimR
Re: Another coolant light issue :)
« Reply #1 on: 17 July 2012, 21:43 »
It stayed on after you took the key out? Sounds like electrical gremlins to me.
Mk2 GTi.
Offline Jimmyrallye
  • 20vt goodness
« Reply #2 on: 17 July 2012, 21:50 »
Yep it stayed on had to disconect battery to make it go out .. It does need the wireing looked at on my car
Offline oakgreener
« Reply #3 on: 17 July 2012, 22:22 »
Wiring fault.  Most likely an earthing problem
Offline Jimmyrallye
  • 20vt goodness
« Reply #4 on: 17 July 2012, 22:34 »
Ok thank guys will get some one to have a look over it for me electrics not my department
