Author Topic: Abf lambda sensor bung  (Read 3528 times)
Offline weazgti
« on: 17 July 2012, 18:36 »
Had a quick look on eBay and there's loads to choose from in different sizes.
Anyone know which one I go for? I have standard down pipe not stainless or anything fancy.
It's One of the last thing to do at the mo, it drives ok just goes through some fuel.
Offline molegti
Re: Abf lambda sensor bung
« Reply #1 on: 17 July 2012, 18:47 »
I understood M18 * 1.5 was standard lambda size.
Offline Diamond Hell
  • Opinions я Us
« Reply #2 on: 17 July 2012, 22:32 »
Or put a sensor in there, not wired in.
Don't really understand why you wouldn't be running with a lambda.  :huh:
Offline weazgti
« Reply #3 on: 18 July 2012, 08:08 »
Why not wire it in?
I be only driven it to work a few times for a proper run since engine going in just to test it really. I don't plan on driving it without one.
« Last Edit: 18 July 2012, 08:22 by weazgti »
Offline Gambit
« Reply #4 on: 20 July 2012, 08:20 »
Are you running the mk3 16v ecu/management or still on kjet?
If kjet then the sensor is not used
  • Opinions я Us
« Reply #5 on: 20 July 2012, 08:28 »
Why not wire it in?
I meant put the sensor in there not wired in as a stopgap, before you wire it in.
Offline weazgti
« Reply #6 on: 20 July 2012, 12:29 »
Running mk3 ecu.
Why not wire it in?
Oh right ok. I ve got Plug for the lambda not connected to anything and the 8v down pipe on as it was. Is it do able in the car? I have a spare down pipe as well.
Offline Mew
« Reply #7 on: 20 July 2012, 13:47 »
Do you mean boss rather than bung?
  • Opinions я Us
« Reply #8 on: 20 July 2012, 14:37 »
Bring the downpipe over to .:WR next Thursday if you want - I've got a couple of old cats with lambda BOSSes on them, we could easily cut one out and weld it into a downpipe and fit it with the car on the ramp in an evening, if you want.
Offline weazgti
« Reply #9 on: 20 July 2012, 14:49 »
Just realised what I ve wrote whoops  :grin: yes I meant boss not bung.
That be brilliant dh. Be good to check out the progress at wr aswell
