Author Topic: hoses  (Read 4792 times)
Offline GTi_James
hoses
« on: 17 July 2012, 14:57 »
got the opportunity to get my N249 bypass done this weekend and ordered the parts, mate down VW is gonna help however i order a 4mm ID silicone pipe and a 5mm T serrated connector, just double checked to the hoses on the "how to" section and its saying 3mm ID pipe and a 4mm T connector, is there any difference? or should it have been the smaller pipes?
many thanks
James
Offline jamie1989
Re: hoses
« Reply #1 on: 17 July 2012, 15:03 »
Nahhh mine is 4mm all round now mate no issues for over a year now.
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline GTi_James
Re: hoses
« Reply #2 on: 17 July 2012, 15:06 »
kool beans, spose its better if its a bit of a wider hole...no pun intended  :nerd:
Offline jamie1989
Re: hoses
« Reply #3 on: 17 July 2012, 15:13 »
haha iv had no issues  :cool:
Offline GTi_James
Re: hoses
« Reply #4 on: 17 July 2012, 15:14 »
and i suppose when you say all over it also means your carbon canister delete too?
Offline cullygti
Re: hoses
« Reply #5 on: 17 July 2012, 15:18 »
3 or 4 mm be fine dude  :smiley:
Offline GTi_James
Re: hoses
« Reply #6 on: 17 July 2012, 15:31 »
cheers guys  :grin:
Offline jamie1989
Re: hoses
« Reply #7 on: 17 July 2012, 15:47 »
Just replace the hoses under the inlet to goes to the fuel reg, then the other one under the inlet to the DV. You can also "T" into the Inlet/dv for a boost gauge too using the 4mm ID silicone tubing.
Basically most tubing under vacuum is 3 or 4mm id so can be changed.
Offline GTi_James
Re: hoses
« Reply #8 on: 17 July 2012, 15:54 »
i was planning on running a gauge after i deleted the carbon canister from the spare valve left over, which one would you recomend then?
Offline cullygti
Re: hoses
« Reply #9 on: 17 July 2012, 16:03 »
if your going to run a boost gauge run it from dv or fpr i find its more accurate from the fpr  :smiley:
