Author Topic: re-trimming headling  (Read 1456 times)
Offline Dannyboi30
  • Golf GTI Turboversary
« on: 17 July 2012, 14:54 »
As above but a curious about the sunroof how do you remove it probly a stupid question lol
this how it all advice welcome
Offline tshirt2k
  • Been there...Done that...
Re: re-trimming headling
« Reply #1 on: 17 July 2012, 14:58 »
Explain what you mean.  :huh: Do you mean the bit that you slide back?
Mk3 ABF 16VT Megasquirt V3
Offline Dannyboi30
« Reply #2 on: 17 July 2012, 15:02 »
yea that bit lol  :laugh:
« Last Edit: 17 July 2012, 15:11 by Dannyboi30 »
Offline gasketface
« Reply #3 on: 17 July 2012, 16:22 »
You can remove the sliding panel with the sunroof still in car.There is a "stop" clip on one of the rails and two plastic plugs (one per rail) at the end of the rails that pull out.
Be aware that the plastic trim at the front of the panel will need to be removed and it is held in by plastic welds (for want of a better description).I did mine recently and had to bond it back in.
I ended up removing all of the foam backing as well which makes the remaining part very fragile so take care.Make sure you use good adhesive,i used high temp spray contact adhesive.
Offline Khare
  • The bear that khares
« Reply #4 on: 17 July 2012, 16:57 »
Use trim fix to glue it. Buy a stretchy fabric if you want a good finish. Sand down the old foam before gluing it. Have someone helping you.
