Golf mk4
Wazzzer
just done engine change asv to ahu 110 bhp both
Topic: just done engine change asv to ahu 110 bhp both (Read 902 times)
terryuk
17 July 2012, 00:42 »
just done engine change asv to ahu 110 bhp both having never taken out a gear box never let alone done a full engine change im very proud its done .. alth i have a few little probs
one my boost only cuts in at 2500 rpm but when it dose its like being in a spaceship , i changed the fuel pump for the asv as i know i would have to change it in the ecu so just put mine on .. the injectors are ahu could this be it or maybe is the fuel timing a little week and needs to be advance ? . two my slave cylinder on my clutch is leeking out the connecton and i have changed the oring
many thanks guys
EsSeX dAn
Re: just done engine change asv to ahu 110 bhp both
17 July 2012, 15:51 »
nice one. bet you had a nice sense of achievement after it all. with the boost, check all the vacum lines are ok, particularly the one leading to the turbo actuator. it might be leaking a bit.
i think i love you.....
terryuk
17 July 2012, 23:04 »
iv done this today and checked everything is tight and as it should be
iv scaned it today and i have code 17656 and iv read people saying the same as me sounds like a bag of hammers and no boost till 2500 rpm and then 100% boost ... should i have put the injectors of the old asv into the new ahf /ahu which ever it is ??
terryuk
18 July 2012, 23:10 »
iv fixed it now was pump timing did it my self sounds lovely now
Golf mk4
Wazzzer
