Author Topic: Pollen filter  (Read 1145 times)
Offline dstv
Pollen filter
« on: 16 July 2012, 21:18 »
Hi guys
Stupid question coming up.....but what will happen if I removed my pollen filter ? Im still getting water in from the base of the pollen filter which is running behind the filter and down the body frame..so Im thinking after a new filter housing and new seal didn't work...can I just remove it and seal it up with something ??
thanks
2000 GTI 1.8t AGU, neuspeed airfilter,Forge 007 dv, R-tech stage 1 remap, Silicone TIP,3" exhaust system, K03s turbo and a empty wallet.
Re: Pollen filter
« Reply #1 on: 16 July 2012, 21:24 »
No pollen filter means no air would get into the car as it is the air inlet.
When I refitted mine I siliconed around the base as well.
Offline dstv
Re: Pollen filter
« Reply #2 on: 16 July 2012, 21:36 »
ok  thanks...plan B then :laugh:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Pollen filter
« Reply #3 on: 16 July 2012, 21:45 »
You're getting him to fix it for you?!  :laugh:
