Author Topic: OIL PRESS STOP ENGINE!  (Read 4819 times)
Offline 1.6mk4GOLF16v
« on: 16 July 2012, 21:08 »
got this show up today intermitantly and the car wont go over 60mph driving in any gear and it feels very weak with no pull at all, even goin over a little bridge i could feel the speed decrease :undecided:
yesterday i went over a speed bump a bit fast n the engine crashed on the floor quite hard, could this be related?
what would be the symtoms or a cracked or leaking sump?
any ideas guys?
1.6 16v AZD
RS8s 225/35/19
Full powerflow decat exhaust
Blanked EGR
Pipercross panel filter
watch this space for the rest...
Re: OIL PRESS STOP ENGINE!
« Reply #1 on: 16 July 2012, 21:10 »
If you have cracked the sump you would have lost all the oil really quickly.
« Reply #2 on: 16 July 2012, 21:15 »
would the car still drive though? at the mo its driving like theres a loss of pressure somewhere
will check oil level and give it a scan in the mornin
any other ideas chaps?
im guessing i should hitch a lift to work tomorrow  :lipsrsealed:
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
« Reply #3 on: 16 July 2012, 21:16 »
Doubt it, maybe a little way but it will soon seize.
Offline cullygti
« Reply #4 on: 16 July 2012, 21:17 »
as said to far and it will seize  :cry:
Offline balderz
« Reply #5 on: 16 July 2012, 22:13 »
Have you changed the oil pick up pipe could be blocked
Offline bobbieboy69er
  • MK4 1.8T AUM
« Reply #6 on: 16 July 2012, 22:16 »
I would imadgine the hard crash on the floor is the culprit  :wink:
Hope its not too costly for ya mate whatever it is
MK4 1.8T AUM|30mm Eibach Springs|Milltek cat back|4mo rear valance|pipercross filter|R-tech Stage 1 Remap|Baileys DV|Powerflex Front and Rear Bushes|312mm Front Brakes|Creation Motorsport TIP and hoses|17" TT Ronals|  220BHP
« Reply #7 on: 16 July 2012, 22:44 »
yh thats what i was thinking, what to check though?
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
Offline itavaltalainen
« Reply #8 on: 16 July 2012, 23:45 »
What to check? Oil level to start with? Is it the low oil warning or oil pressure warning?
If low oil light (yellow/amber):
could be that you ripped the sensor / cable off..
If pressure light (red):
Next, take the undertray off (if not ripped off) and see if there's a leak or see if the oil pan is scraped or bent. If it is and you don't have leaks it could well be oil pump pickup or if you done well the lot but that you hear very much.
Hope for you that it's only low oil or pan... At least that you can fix during a weekend and an old oil pan from scrappy.
Offline Dalo Harkin
« Reply #9 on: 17 July 2012, 07:29 »
If you hit the floor at the back of the sump then you could have mashed the oil sensor on the underside of the sump
