Author Topic: coilpack recall code  (Read 1818 times)
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
« on: 16 July 2012, 19:34 »
Does anyone know what the coil pack code for the AUM engine is that is being recalled. i.e. does it end in a D or a G ?
Thanks
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline dasan
Re: coilpack recall code
« Reply #1 on: 24 July 2012, 13:27 »
I just sorted my recall out over the phone, just gave them my reg and they said bring your motor down.
VW Golf GTI - 1.8T 2003 - Reflex Silver
Offline Nino
« Reply #2 on: 24 July 2012, 15:02 »
huh?  :undecided:
Current - MK6 GTi Edition 35
Offline NobbyMk3GTI
  • Forums are always full of dicks!
« Reply #3 on: 24 July 2012, 15:26 »
« Reply #4 on: 24 July 2012, 15:47 »
They replaced mine foc  :smiley: I only asked the coil pack number code, because a while ago I bought 4 new coil packs from TPS, before I new about the recall. So what I did was put the old coil packs in before I went to VW, so I now have a spare set as well  :wink:
Offline Chris#101
« Reply #5 on: 24 July 2012, 18:38 »
probably be easier to say the engine code and year of your car!
mine was recalled on an 03 AUQ 180 4 months ago
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline Nino
« Reply #6 on: 25 July 2012, 08:27 »
Would someone be kind enough to explain what this all about? :)
Offline cobalt6700
« Reply #7 on: 25 July 2012, 10:36 »
My coil packs kept popping out, so I rang the stealers and gave them my reg, 4 spanking new coil packs for free.
Just ring them up and ask, who doesnt want some brand new coil packs?  :smiley:
1993 GTI 8v 5dr matt black and green - the 'sh!tball rally car'
1997 GTI 8v 3dr metalic black - the daily driver
2002 3DR 1.8T AUM silver - the new daily
1993 Jeep cherokee 4L - the weapon :D
« Reply #8 on: 25 July 2012, 15:57 »
It only applies to certain cars, mainly AUM and AUQ I think. AGU are not part of the recall afaik...anyway, the reason I asked what the code is on the recalled coilpacks, is because I had already replaced mine before I new about a recall. Therefore, I wanted to know what coilpack code was being recalled, because I wondered if the ones I had bought from TPS about a year or so ago were ok, or were part of the recall batch. It turned out that the ones I had bought from TPS were the good ones, and therefore if I left them in my engine when taking my car to VW for the recall work, then they would not of replaced them. Soooo, I took them out and put the  original faulty coil packs back in so that they would replace them foc, which they did. And now I have a spare set of coilpacks  :smiley:
