Author Topic: Freeview on your iPad/iPhone/Android device  (Read 1953 times)
Offline DubFan
« on: 16 July 2012, 13:21 »
Just seen that Humax (makers of fine Freeview and Freesat boxes) have brought out two Freeview products for mobile devices.
One is a pocket sized Freeview box that connects to your iPad/iPhone/Android phone wirelessly allowing you to watch freeview on your mobile device.
The other is a Freeview dongle to plug into your iPad:
Available from the Humax website: http://www.humaxdirect.co.uk/prodCat.asp?cat=tivizen
Offline Kerrse
Re: Freeview on your iPad/iPhone/Android device
« Reply #1 on: 16 July 2012, 15:57 »
You can get freeview already just from an app but that is wifi only i think
Offline Devilz
  • Cruisin is not a crime
« Reply #2 on: 16 July 2012, 16:12 »
You can use app called tvcatchup on iphone/ipad to watch freeview
Offline DubFan
« Reply #3 on: 16 July 2012, 16:17 »
But both of those require you to have an internet connection.
And it's using up your bandwidth to stream video to your phone.
This device is different, it is a Freeview receiver, which (if you get the little box) picks up the TV signal and relays it to your phone over wifi. Or if you get the iPad dongle, it receives the signal and then displays it direct on the iPad screen.
The big advantage of these products is that it doesn't require an internet connection or use up 3G bandwidh, just the ability to pick up a freeview signal.
« Last Edit: 16 July 2012, 16:55 by DubFan »
Offline Rhyso
« Reply #4 on: 16 July 2012, 16:29 »
Nifty little device  :nerd:
Offline bobbieboy69er
  • MK4 1.8T AUM
« Reply #5 on: 16 July 2012, 21:42 »
Nah TV Catchup works via 3G, i watch it on the tube sometimes.
MK4 1.8T AUM|30mm Eibach Springs|Milltek cat back|4mo rear valance|pipercross filter|R-tech Stage 1 Remap|Baileys DV|Powerflex Front and Rear Bushes|312mm Front Brakes|Creation Motorsport TIP and hoses|17" TT Ronals|  220BHP
  • MK4 1.8T AUM
« Reply #6 on: 16 July 2012, 22:11 »
ahhh just read you thread properly!  ill shut up.  TV Catch up is good but as you say uses the tinterweb either 3G or wi-fi...
Offline murraymint
« Reply #7 on: 16 July 2012, 22:14 »
Could I use one of those with my iPad as its only a wifi model?
josh
Offline Adam
« Reply #8 on: 17 July 2012, 01:30 »
Indeed
Down Hill From Here.
