Author Topic: 2.0GTi 55 plate ECU draining battery  (Read 1698 times)
Offline Monkeys
« on: 15 July 2012, 19:53 »
After a non start, AA diagnosed ECU draining battery. Temp fix involves removing fuse 23 at end of journey to prevent overnight drain.
Anyone familiar with this problem. Given location of ECU (under windscreen scuttle i think), wondering whether some water ingress. Also wondering whether connection
to ECU is problematic, rather than ECU itself as no other faults. Thanks for any help.
Offline bacillus
Re: 2.0GTi 55 plate ECU draining battery
« Reply #1 on: 15 July 2012, 20:28 »
Do you have an upgraded head unit?
Without traction power is nothing!
Offline Gene Hunt.
« Reply #2 on: 18 July 2012, 15:10 »
.........x2 usually the reason for this.
Candy White ED35.
