Author Topic: fitting R32 front ARB  (Read 1910 times)
Offline 1.6mk4GOLF16v
« on: 15 July 2012, 10:13 »
guys is there a how to guide anywhere? wanna get it done today  :cool:
1.6 16v AZD
RS8s 225/35/19
Full powerflow decat exhaust
Blanked EGR
Pipercross panel filter
watch this space for the rest...
Offline DunnDeal12
  • Limited
Re: fitting R32 front ARB
« Reply #2 on: 15 July 2012, 10:36 »
cheers for that but guide needed for a 2wd
fitting the arb to my 1.6 so i can lower the front a bit more
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
Offline GunnerCP
« Reply #3 on: 15 July 2012, 10:43 »
It's very much the same process, Im sure that 'guide' and your eyesight/common sense will be enough....
It's not that hard, you'll soon figure out what needs to be undone, get a long breaker bar/air tools for the subframe bolts. If they haven't been touched in 10 years or more they can be fun....!
« Reply #4 on: 15 July 2012, 17:01 »
yeah i guess your right, will attempt it next weekend now
am i ok to use the same drop links or do i need different ones?
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
Offline DunnDeal12
  • Limited
« Reply #5 on: 15 July 2012, 17:26 »
*edit* just found out you dont really need adjustable droplinks as the old ones can be spaced out.
« Last Edit: 15 July 2012, 19:52 by DunnDeal12 »
Offline GunnerCP
« Reply #6 on: 15 July 2012, 19:25 »
Got new bushes too?
« Reply #7 on: 16 July 2012, 21:11 »
ill be using the droplinks which are already in (1.6 AZD), think theyre shorter than the standard r32 ones?  :undecided:
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
« Reply #8 on: 16 July 2012, 21:12 »
Got new bushes too?
yh got some cheap ones from europarts
1.6 16v AZD
RS8s 225/35/19
Blanked EGR
