Author Topic: newbie help  (Read 1477 times)
Offline max38
  • 1.8T AGU
newbie help
« on: 15 July 2012, 08:29 »
hi all im new to the site and have a 1.8t agu with a few problems have run the codes and came up with 01247 , 01262 , 16486 , 16518 and 16519  any help pointing me in the right direction would be greatly appreciated also whilst having a look under bonnet i noticed the small hose coming off the top of the recirc valve is not going to anything im thinking this is not right any pics of where it goes to would be handy
Offline oceanic-green
  • Mk4 1.8T Aum 260+ Bhp 273 TQ
Re: newbie help
« Reply #1 on: 15 July 2012, 08:39 »
you will find this link very handy http://wiki.ross-tech.com/wiki/index.php/Category:Fault_Codes  Just click on the code and it will come up with possible causes and solutions. Your first code is on the bottom of that page, just keep flicking through to find your other codes  :wink:
As for the dv pipe not going anywhere, it should go to a thin metal tube more or less below the tip. Well it does on my AUM, I presume it will be the same on an AGU, but not sure
Mods: R-Tech custom remap, Beachbuggy K250 Turbo, Forge 007 DV, RAMAIR Jetstream 108 induction filter, silicone piping throughout, R-Tech Supersize TIP, 42 Draft Stealth Catch Can, N249 bypass, Ported Manifold, Toyo Sports FMIC with 2 & 1/2 pipes, Custom made full turbo back exhaust & 2 & 1/2 " downpipe and 200 cell sports cat. BAM injectors, Turbosmart Boost Gauge, BBS CK Wheels, 312mm Brembo front discs and pads, Carbon canister delete and last of all, a liquid cube!
Offline max38
  • 1.8T AGU
Re: newbie help
« Reply #2 on: 15 July 2012, 08:44 »
thanks for the info will go see if i can reconnect that hose asap
Offline max38
  • 1.8T AGU
Re: newbie help
« Reply #3 on: 15 July 2012, 08:57 »
another quick question would these faults bring up a light on the dash as ive none showing
Offline Toby
  • Car - less
Re: newbie help
« Reply #4 on: 15 July 2012, 09:31 »
Ushually not, only vag com.
Currently down under
Offline max38
  • 1.8T AGU
Re: newbie help
« Reply #5 on: 15 July 2012, 14:20 »
new pipe now fitted cant say it feels any different have rescaned still same codes so time for a new m.a.f and n75 valve
