Author Topic: Slave cylinder flexi/pipe  (Read 1359 times)
Offline CJA321
« on: 14 July 2012, 19:05 »
Had a bit of a f**k up fitting my slave cylinder pipe today.
Long story short, snapped it being a tad rough when i was tired and shoulda really stopped working lol.
Anyone know if you can just put a standard bit of brake pipe straight through to it?
Or get a random double female ended flexi hose and make one up with brake pipe?
Cheers guys
« Last Edit: 14 July 2012, 19:26 by CJA321 »
Offline Dan_GTi8v
Re: Slave cylinder flexi/pipe
« Reply #1 on: 14 July 2012, 20:05 »
is this the clutch slave pipe? I would of thought any bit of pipe would do as long as it doesn't expand under pressure.
Offline CJA321
« Reply #2 on: 14 July 2012, 20:12 »
Aye thats the one :-)
Offline Dan_GTi8v
« Reply #3 on: 14 July 2012, 20:26 »
brake pipe should work as the brake system is run using the same principle and uses the same fluid :)
Offline Bandit127
« Reply #4 on: 14 July 2012, 20:36 »
The same principle as the connection from the body to the brake caliper applies. Lots of movement between the ends of the pipe - it requires a flexible hose.
A breakers would be the starting point if it was mine. Dealers next - and a custom made braided hose for maximum bling and pedal feel is the ultimate.
« Last Edit: 14 July 2012, 20:38 by Bandit127 »
