Author Topic: People who have fitted their own TIP  (Read 3290 times)
Offline Dalo Harkin
« on: 12 July 2012, 12:35 »
did mine last night as it looked 'easy' what I thought would be a 20 minute job ended up being an hour.
Jacked NS up and placed an axle stand under
Got underneath the car and removed the 5mm bolt holding the old TIP to the turbo, went topside and removed everything connected to the old TIP and removed it all easy enough.....
New one going in reversal to fitting, could I get the orientation of the TIP anywhere near the turbo no.... removed the 8mm bolt that holds the coolant pipe in to give you supposedly more room (about 1cm I got  :angry:)
In the end I got it fitted and onto the turbo, went underneath again to tighten the jubilee clip and I am sure its not as tight as it should be but didnt want to snap it :shocked:
So just to let people know, its not as easy as you first think, I was going to do my own turbo but after looking at this I think I'll get someone else to do it  :smiley:
Offline jamie1989
Re: People who have fitted their own TIP
« Reply #1 on: 12 July 2012, 12:50 »
I found it easy, about 45mins start to finish with a little messing about  :smiley:
hardest part is gettin the tip on turbo and doin up the jubilee.
1.6-1.8t AGU K03s, Forge actuator, Forge 007p, turbo back exhuast, Ths front mount, Catch can, 5 piece silicone boost pipes and creation sports tip. Stage 2 atm 232bhp 270lbs. Waiting for custom mapping :-)
Offline Dalo Harkin
« Reply #2 on: 12 July 2012, 12:52 »
I must have tried 5 times to get the TIP onto the turbo and on the 6th time, it just slotted on, I thought 'you gotta be sh1ttin me' checked from underneath and low and behold it was on, it would have taken 30 mins if It went on first time ol
Offline shaft69
« Reply #3 on: 12 July 2012, 14:03 »
Took me about 40mins do mine.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
Offline lemski
  • 16v
« Reply #4 on: 12 July 2012, 14:56 »
I thought it was fairly easy. But my engines in a mk2. Just unbolted old tip and slipped new one on
Offline Dalo Harkin
« Reply #5 on: 12 July 2012, 15:06 »
There is a hard coolant line that just didnt budge for me leaving the gap to install the new TIP very minimal, you had to twist it and hope for the best  :laugh:
Offline lemski
  • 16v
« Reply #6 on: 12 July 2012, 15:14 »
Yeh I find my tip touches it slightly. But she squized on there. The worste bit was wen I took it back of the otherday to trim it down.
Offline Mr_Orange
« Reply #7 on: 12 July 2012, 20:04 »
Which manufacturers TIP is this?
Build thread clicky
Offline Dalo Harkin
« Reply #8 on: 12 July 2012, 20:07 »
Creation Motorsport, oh and I forgot to say the little metal part that sticks out of the bottom nearest where the turbo meets the TIP was where the carbon canister delete pipe went to so just blocked it with a large nut and jubilee clip  :wink:
Offline golf-sib
  • Турботазик
« Reply #9 on: 12 July 2012, 21:33 »
Had no problem with these, I have a black creation one, and had a blue Demon motorsport one prior but changed it as I wanted oem look. First time doing it is a pain, but once you've done it a few times its not too bad.
VW Golf - k03 AGU - 200BHP
1.8T AGU..
R135
  24
