right people please dont hate on me for this ! i followed this great guide but found it was missing a few little bits like extra bits you need and some knoledge on what to remove and what not to , so im just going to copy and paste their guide and just add to it . i hope it helps out a few people and doesn't affend the makers of the original guide im sorry ! if you ever find you need a hand with this job PM me ill help you out best i can .....
Parts needed:
Electric window regulators x2
Door loom x2
Window switch x2 (with mirror adjuster)
Dash loom x1 including thermal fuse
Door cards (recommended) or blanks to remove winder handle.
Two electric mirrors (recommended)
First off, the electric window loom stretches from one door to the other and simply plugs in to the connector blocks near the doors, the other ends plug into the fuse box. There are several smaller connectors, depending on the model of your car may or may not have these available to plug in to the fuse box, Most do so if possible just plug them in to the correct spare ones hanging down behind the fuse box, this enables things such as the back lights in the switches etc.. Although to have full working electric windows its only necessary to connect the smaller + power lead and the main power lead. The main power lead should have a thermal fuse already connected, this just clips to the top of the fuse box.
Step 1 (Door card removal)
Prise the door handle covers off with a flat head screw driver, behind this there are two large crosshead screws. Undo these two. Remove your window winder, first off, wind the window down but leave a few inches, you will thank me for that later, Look at the base of the window winder, there is a ring which you simply push in with a screwdriver, it unclips and you can pull the winder off the shaft. Next, you need to unscrew your door pin. You can now prise off the door card, I recommend starting at the bottom, personally I grab the little storage part on the door card and give it a pull, otherwise, pop a large flat head screw driver behind the door card and pop all the retainers off, remove door card. Watch out for the speaker plugs, disconnect them now. Once removed you can either cut or peel the sound deadening foam away, early models just have plastic sheet.
Step 2 (removing the old regulator)
All you should need here is a 10mm spanner or ratchet, ideally both. You may need to pop the winder back on to adjust the glass so you have access to the glass clamps, it’s usually quite easy providing the windows not closed. Unbolt the two 10mm bolts that clamp the glass and pop out the little plastic semi circle sticking half in the door frame holding the cables , it might be stuck in the rubber so give it a yank and raise the glass up by hand. i use a garden peg or rolled up card to wedge into the glass to keep the glass up. Unbolt the 2/3 10mm bolts on the door that hold the regulator in place, you can now remove the old regulator.
Step 3 (removing the old loom)
There will be the old loom which feeds the central locking remove all of this and unclip it, pop the rubber boot off the door disconnect it and you can prise the plastic connector out.
right heres where i wanted to add mass info !
first off remove the n/s trim that hides all the wirring on the passengers side of the car , you then need to remove the three phillips screews holding on the rear 3/4 panel with the speaker in , i also removed the rear bench for access , then remove black bit on the boot liner held on with torx bits (t25 i think ) then you can up clip the c/l motor and working from the rear to front remove the wiring from the c/l pump all the way up the car . now remove the n/s kick plate and lower glove box then upper glove box .unplug the black bits of the loom out the white plug in the door frame . carry on to remove the loom behind the dash as far as your arms can reach . then remove the surround on the clocks and remove the clocks , bonnet pull . and drivers side kick panel remove the cover on the fuse box and the big plastic panel held on by 4/5 screws and the smaller panels around the pedals , also found removing the drivers air vents helped aswell and drop the fuse box , carry on pulling the loom out from drivers side and unplug ther power from the fuse box and the earth out the brown connector block on theright , also the c/l is plugged up here to the ecu or something . now unplug at white connector block on driveres door shut and you should have a whole loom out the car now ! please bear in mind there is a connector from the white blocks that stays near the blocks that are for speakers !
Step 4 (fitting the electric regulator)
Hopefully it wontt be set to fully closed, when I got mine they were which makes it very tricky! But far from impossible, Fit the regulator into the door, its a bit of a wiggle, then hold the motor up to the area it sits in and pop the 10mm bolt in, move the other parts of the regulator until the other two bolt holes are lined up and nip them up. Now you can carefully drop the glass down into the two clamps, ensure it’s seated properly into the rubber holders otherwise it might go crunch! Tighten the clamps up. if the window is set to up , kit the new dash loom out then come back to this bit so you can power the reg up and drop the window down so you can reach the bolts with ease !
Step 5 (Fitting the loom)
The new loom just clips in place of the old one, feed it through, plug in the central locking plugs, window motor, speakers, and window switch, you will notice there is a spare up at the top, at this point you might want to fit electric wing mirrors to that as they will just plug in and work! There will be an extra plug on the drives side for the wing mirror adjuster switch. Ensure its well clipped in and out of the way of the window mechanism etc... Feed the wires through the door DONT CLOSE THE DOOR! It will crush the door connector pins! In fact you can go ahead and plug it in now. Push and twist, then refit the rubber boot.
Step 6 (Dash loom)
Once both doors are all kitted up, you can feed the dash loom so it spans from one side to the other, drop the fuse box down so you have access to the rear of it. You can’t go wrong with the door ends of the loom, plug them in to the door connector, it will only plug in one way so plug that in both ends and move to the fuse box, There are a few different connectors for the lighting in the switches etc.. There should be the respective plugs hanging about up there, I’m not sure if all models would have this though. There are two important things here, the earth I have completely forgotten where it goes, it either plugs into the fuse box earth block or to the chassis earth plug just up from the door connector, it may even bolt to the body work, you will see when it’s in front of you so connect that up. You may want to disconnect your battery now to be safe. Plug the big red connector into the back of the fuse box, I’m not sure of the pin numbers but someone will be able to help with that. There is a smaller switched ignition feed which also plugs into the fuse box. Once everything is plugged in, you can reconnect the battery and see if it works, temporarily plug the window switches in to give them a go.
please note here , the new loom runs on the oposite side of the car down to the c/s pump from the side you took it out on most looms , you mayt find you have extra plugs hanging down and not plugged in the c/s plug yet , if so chop the old connector off the old loom and connect it to the respective coloured wires hanging down at the fuse box , chop the conectors off fit to the old plug and connect up . the red plug goes in the fuse box next to the red plugs and the earth goes up to the earth block where the other came from , the window bits just knock on to the side of the fuse box
Step 7 (refitting door cards)
Easy bit now, refit the sound deadening foam or plastic as good as you can, use duct tape if necessary. Hold up the door card, plug the speakers in, and feed the plugs for the switches etc.. through the correct holes in the door card. Fit the door card on to the poppers, replace the two screws and spin the door pin on. Now plug in the window switches and the wing mirror switch, this just pushes on. Sit back and admire your work.
