Author Topic: Gti converting 5 stud to 4 stud  (Read 5335 times)
Offline murraymint
« on: 11 July 2012, 20:36 »
Hiya, random question but. I've been doing some searching into what's needed to convert the rear of a gti from 5 stud to 4 stud. And I found that all I would need to change is the discs to mk2 discs?
Is this right or do I need anything else?
And the reason I wanna do this is I wanna keep my wheels if I get a gti, first plan was to put the abf in my 1.6 but converting the gti to 4 seems a lot less work
josh
Offline JC
  • Back in the North.
Re: Gti converting 5 stud to 4 stud
« Reply #1 on: 11 July 2012, 20:41 »
if only it was that simple  :grin:
Offline murraymint
« Reply #2 on: 11 July 2012, 20:44 »
That's what I was thinking when I read it lol  :grin:
Mk2 stub axels, discs....?
I got the fronts sorted
josh
Offline murraymint
« Reply #3 on: 11 July 2012, 20:45 »
This is what the search returned. Hence question
This is what confuses me, isn't a mk3 gti 5 stud?
Or are the early ones 4 stud later ones 5 stud?
All Mk3 GTI are 5 stud.
The wheel screws into the disk, so in effect the disc is the hub.
A Mk2 disk is direct swap but 4 stud.
josh
Offline twotwofour
« Reply #4 on: 11 July 2012, 20:48 »
It screws in to the stub axle which the disk mounts to
Mk2 small bumper 16v 3dr golf gti
Mk3 5dr 8v golf gti x2
Need a mk1 gti, mk1 caddy, mk3 vr6
Offline murraymint
« Reply #5 on: 11 July 2012, 20:50 »
So all I need is 4 stud stub axels and 4 stud discs?
josh
Offline tweed
« Reply #6 on: 11 July 2012, 21:16 »
I thought the gti rear beam was more narrow than the rest?
Offline tweed
« Reply #7 on: 11 July 2012, 21:19 »
not that it will affect you but if you set your et to the 1.6 the wheels might sit in a little more on the gti.
Offline murraymint
« Reply #8 on: 11 July 2012, 21:21 »
Yh think the will sit closer to the arch on the gti. But I wanted to get 10mm spacers for the 1.6 so will be fine lol, I also have an arch roller if needed.
You know what I ned tweed? I did search  :grin:
josh
« Reply #9 on: 11 July 2012, 21:25 »
Not something I would consider, the main issue / view that came up in the last thread was would it be safe, GTI's are built with 5 studs for a reason plus how would an insurance company view the switch.
With the work involved it makes more sense to buy wheels that fit.
