Author Topic: GOLF MK3 GTI EARTH POINTS  (Read 3191 times)
Offline GOLF-MK3-GTI
« on: 10 July 2012, 21:26 »
HI Everyone,
Would any of you fellow enthusiasts know where all the earth points are for an 8V GTI?,
Recently it has started giving me starting problems, So i have been advised to check the earth points.
Thanks
Offline Screech16v
  • MK3 20vt AGU
Re: GOLF MK3 GTI EARTH POINTS
« Reply #1 on: 10 July 2012, 21:28 »
Theres some main ones under the battery tray.
« Reply #2 on: 10 July 2012, 21:37 »
Thanks for the reply,
Any more earth points, Keep them coming.  :sad:
Offline Screech16v
  • MK3 20vt AGU
« Reply #3 on: 10 July 2012, 21:46 »
Theres one off the head to the coil
« Last Edit: 10 July 2012, 22:28 by Screech16v »
Offline jiminbmth
  • brings back the sunshine!
« Reply #4 on: 10 July 2012, 22:06 »
Wot are the symptoms? might be something else? :smiley:
jiminbmth ;)
Offline tweed
« Reply #5 on: 10 July 2012, 22:45 »
Starting cold problems? Starting when hot problems? Does it have problems starting cold and hot?
« Reply #6 on: 10 July 2012, 23:08 »
Hi
when engine is warm, it sometimes refuses to start, until you leave it for a while
I've changed the coil and ecu temp sensor, the last coil I had kept on doing the same thing, so I changed it and 3 weeks later, the problem is back,
However I took it for a spin today and it didn't give me a problem at all, so I think it's intermittent
any help is appreciated
Offline sharki786
  • GOT BOOST??
« Reply #7 on: 11 July 2012, 01:09 »
have you changed the fuel & ecu relays? As i had a simular problem but my car kept cutting out and i think it was the ecu relay. They ment to be warm not hot. Have a search in the mk3 section to see what number relays you need.
Think they only £11 a pop from dealers.
*****MK3 Anniversary*****
*****MK4 GTI T*****
« Reply #8 on: 11 July 2012, 09:53 »
I'll have a look, I have my doubts on the coil, coz the last one I had in was doing the same thing, I put in a new one and it only lasted me 3 weeks before it started giving me staring problems when warm, so I changed it and again 3 weeks later doing the same thing, ohh by the way it a budget make one lol
btw my car does not turn off when being driven or once started
« Last Edit: 11 July 2012, 09:55 by GOLF-MK3-GTI »
Offline sharki786
  • GOT BOOST??
« Reply #9 on: 11 July 2012, 13:38 »
you need to get a decent or oem eq 1. My coil pack went & i replaced it with a bosch 1 (the original 1 was made by bosch) & its been good for 2-3 yrs now.
*****MK4 GTI T*****
